Question about HP DeskJet 9800 InkJet Printer
Deskjet 9800 disassembly
Hi
does anyone know where i can find instructions on how to take apart the 9800? I need to replace the ink carriage
Thanks!
  • Anonymous Oct 31, 2008
    i got this problem also...
I have the same problem!
Posted on Oct 28, 2008
I have a Deskjet 845C. It wont stop flshing both the power & resume buttons. I have turned it off & on (as per the instruction from the user manual) several times, but it makes no difference. There...
Hi
Normally this can be the reason what is known as Carriage Friction. Try to put a little oil on the steel rod and also do make sure if the carriage movement is smooth and nothing effecting its movement.
Take care.
Aug 23, 2011 | HP DeskJet 845c Printer
Hi, I am looking for a print head for my HP deskjet 9800. C8165Al. SNTRC0405. Do you know where I can such apart? Also is the print head the same as the print head carriage assembly?
I think the print heads are built into the ink cartridge on this model. Try calibrating the printer, if this does not work you can replace the cartridge presenting the issue, or take it out and leave wet paper towel over the printheads, sometimes this unclogs them
Aug 20, 2011 | HP DeskJet 9800 InkJet Printer
My Deskjet 9800 has both cartridge lights flashing. I've put in new cartridges and ensured that they are properly seated. I cannot print a test page.
you will need to replace the carriage assembly because the cartridge has punched a small hole in the circuit contact board, which broke the circuit
Feb 06, 2010 | HP DeskJet 9800 InkJet Printer
Alignment problems with hp 9800
Look inside, use alcohol to wipe the encoder strip. The encoder is the clear plastic that runs across behind the carriage assembly. You need to wipe carefully, maybe a Q-tip but don't press too hard. Ink and spots on that strip cause the problem you are seeing.
Dec 29, 2009 | HP DeskJet 9800 InkJet Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
DeskJet 9800 Streaks in Color Print
That is the problem, you need to expost the track wheels and clean them with a paper towel soaked in rubbing alcohol.
Jun 27, 2008 | HP DeskJet 9800 InkJet Printer
Where can i the hp 9800 ink socket flex cable to purchase ?
Are you asking this because when you tried to place your ink cartridged you broke the cable with a metal part in the printer?
I just had the same problem... I need to replace that cable. I dont' even know how t otake this thing apart yet!
please reply to NGR7000@hotmail.com
let mek now if you have the same problem. I think we can call HP and tell them about this problem. maybe get some resolution.
Rafael
May 13, 2008 | HP DeskJet 9800 InkJet Printer
Hp deskjet 9800 power and paper out lights flash together
Remove the back jam access cover and see if there is anything in the way. Also, Try removing ink gunk from the resting area.
Jun 16, 2017 | HP DeskJet 9800 InkJet Printer
HP DeskJet 9800 InkJet Printer Logo
907 people viewed this question
Ben Johnson
