Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
My dewalt impact driver started cutting out as if the battery was deadbut if i pull the battery to either side it seemed fine now its not coming on at all
  • Anonymous Feb 28, 2009
    when pulling trigger it works sometimes , cuts out . Probs switch i agree , but where do i get one that isnt nearly the price of whole new naked machine ?
  • admldj May 01, 2010
    hey i brought it too my local dewalt agent he took it apart and found out it was the bushes unfortunately this you cant buy brushes for this model you have to buy a new motor the price would have been €99 plus labour told him i'd leave it he said that newer ones (model for li-ion) did have replaceable bushes and were backwards compatable price €350
    checked on ebay and got one from the states for €109 delivered using it since about a month after i posted about the old one only problem is the pozi tips unless you buy good ones €2 each you will eat them i was stuck one day and went trough a box of 25 in 8 hours! hope this helps
Switch could be a problem
Posted on Sep 22, 2008
Dewalt dw297 impact wrench does'nt work at all. the cables does'nt seem broken, so don't know what to look for.
A good place to start with Dewalt tools is the switch. Take the front off the handle and pull the switch out far enough to test the posts on the back. Plug the cord in and check for voltage where the cord attaches to the switch. No voltage, bad cord, replace the cord. If you have voltage, the cord is good. With some help, hold the switch on and check for current on the motor side of the switch. If no voltage, replace the switch. If there is voltage there, you are going to have to check the brushes, armature and/or field for continuity or shorts.
Jun 27, 2012 | Dewalt DW297 3/4-Inch Impact Wrench
My impact driver is not this model its a dc827 but it quit hammering it just free wheels if you just slightly pull the trigger is kinda works is there anything i can do to fix this prolbem?
The pinion on front of motor is slipping on motor shaft. It seems to be just a press fit. Seems like a flaw in design. I had same problem. I took my dw056 apart and took pinion off motor and pressed groves into motor shaft with side cutter pliers. then pounded pinion back onto motor shaft. We will see how long this lasts the motor shaft is a softer metal. I feel the motor shaft should be hardened steel like the pinion and have a shear pin or some sort of spline to attach to pinion. Would like Dewalt to offer fix for this as I only used dw056 a couple of times before I had problem.
Jul 16, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Impact not working correctly
The pinion on front of motor is slipping on motor shaft. It seems to be just a press fit. Seems like a flaw in design. I had same problem. I took the dw056 apart and took pinion off motor and pressed groves into motor shaft with side cutter pliers. then pounded pinion back onto motor shaft. We will see how long this lasts the motor shaft is a softer metal. I feel the motor shaft should be hardened steel like the pinion and have a shear pin or some sort of spline to attach to pinion. Would like Dewalt to offer fix for this as I only used dw056 a couple of times before I had problem.
Jun 05, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Only full power for full trigger pull
I had same issue with Metabo hammer drill. It was faulty triggrer. Replace it and it shoul be fine.
Juraj
Jun 04, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt dw567
if i'm confused i'm sorry, but don't confuse and impact driver with a hammer drill
2 different tools altogether
Feb 27, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Hi from dublin,my third dewalt dw054 impact 14.4v cordless drill,they all lose power,as if the switch does not work,but i think the motor is gone.. They all went the same way after two years..great drill...
Hi there, the first thing you need to do is check the carbon brushes, there will be two of these one at each side of the motor, if these are ok then test if power is getting to the motor, to do this you will need to split the casing on the tool in half. You may need a torx driver to undo the screws on the casing. Once you have removed the screws, very carefully split the casing making sure you leave the gearbox assy, motor and switch in the other half. Insert battery onto the unit and get someone to hold the motor in place just incase the machine starts. get a voltmeter, follow the wires from the switch to the motor and where the wires attach to the motor put the probes of the voltmeter and pull the switch to engage it. You should be gettting a good voltage now, If you are then the switch is ok. hope this is of some help
Dec 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt 18v impact drill
if you use it every day, it would be normal for the battery to be at the end of its life. ni cads are usually good for 300 charges/discharges
Jun 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Tired old Dewalt dw056 impact driver
It needs a new battery pack. Rechargeable batteries eventually wear out and no longer hold a charge. The tool runs only briefly and the battery is exhausted again. The big home centers and online sources sell replacements. There are also companies that say they can rebuild your battery pack at much lower cost than replacement. I have no experience with them.
Apr 23, 2009 | Dewalt DW056 18 Volt Cordless Impact...
02-03-09 Tues. 9:30am CST Hi Tech Help I have a DeWalt 1/4" Cordless Impact Driver DW056. It seems to slip when the trigger is engaged when loosening fasteners. I think the driver started impacting...
its supposed to impact immediately that is what gives the tool its power. once you get used to it you will use it for everything its lighter and more powerfull than the drill. just dont use spade bits in it or it will shatter them. try to buy tips that are impact ready
Feb 03, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
231 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
