Question about CPQ/ PCA Startech Dual Port MP9835L/PCI 16C550 Serial IO (389348001)
PCI2S550 I'm trying to instal one "2port PCI 16C550 Serial Card" on a gateway profile 6, but the drivers on the cd. never works. do you have other can i use for?
My audio did not work anymore
If the audio was working earlier and than all of a sudden quit working I suggest making sure that it is plugged into the correct port, than restart the computer and try to play a song than. If it still doesn't work, sounds like your on-board audio card is finished. ALSO make sure your volumes aren't muted.
Sep 06, 2012 | Gateway One Computers & Internet
What video cards fit into a gateway profile 6
You won't ba able to fit a video card in this computer. Because it is a all-in-one PC.
May 26, 2012 | Gateway Computers & Internet
Soundcard problem
if onboard your suond card buy pci sound card w/ cd driver install it to pci slot in your pc turn on pc then install driver........done
Feb 23, 2010 | Gateway E-4100 Special PC Desktop
My gateway profile 5 will not install the network driver. 1394 net adapter is installed but doesn't connect me to the internet.
1394 is NOT your Network adapter... you need to go to device manager and look there for any "Network Adapter" then right click and "Update Drivers". Your network card will have a "Name" or say PCI network device or the like. Thats the driver you need to find and install. Hopefully it is on your drive somewhere.
Jan 31, 2010 | Gateway Profile 5 PC Desktop
Uninstalled pci express nvidia card drivers and pulled the card. (onboard graphics in use now) however, hardware profiles, other devices, SMbus controller have a yellow ?, indication. I'd like to...
Nice description for a change, thanks. You need to reload the mobo driver of CD if you have it or download from gateways site.
Does your graphics card have an on borad fan, if so it must not be working, or if only a heat sink then falty card.
Only reason graphics cards overheat is = NO fan working / clogged or if heat sink then card is faulty.
Jan 20, 2010 | Gateway GT5228 PC Desktop
Physically remove nvidia 8600gt video card from
The video card is in the AGP slot on the motherboard.
There will be a plastic clip at the back of the slot that needs to be pressed to release the back of the graphics card.
When you insert the new graphics card this clip should automatically lock in the new card.
Nov 02, 2009 | Jaton NVIDIA GEFORCE 9400GT PCI, CTLRDDR2...
Hardware not found?
please try to clean the mouth of the PCI slot by wiping with a white paper..... re fix it, power the machine and allow the hardware to be detected... you can now try installing the driver software ....
Aug 07, 2009 | Parallel PCTek High-Speed 2-Port PCI...
I have a Gateway E2100 and would like to install an upgraded video card. Can you reccomend a slimline PCI card that would work in this PC?
EVGA Geforce 9400 512mb PCI - $70 and low profile ready so it should fit in your case.
Jul 13, 2009 | Gateway Computers & Internet
Keyspan SX Pro Serial Adapter set up
Do you have the driver cd of the card. For setting up a PCI card simply insert it in the pci slot and install drivers when it asks you.
I think your PCI card needs drivers
Oct 02, 2007 | Keyspan SX Pro (SX-PRO4) Serial Adapter
Proxim Orinoco 8482-WD PCI Card, Driver installation locks Win-XP
Try the other way around,first install the card then boot the system up. When Windows finds the card and asks for the driver, insert your driver cd and choose install driver manually and point windows to your cd drive to force the use of the correct driver. It may be that windows is trying initially to install the generic driver.
Feb 05, 2007 | Proxim ORiNOCO Gold (8482-FC) 802.11a,...
Computers & Internet Logo
119 people viewed this question
Alun Cox
