Question about Zebra Stripe S600 Thermal Label Printer
Not printing the correct text / picture
When starting to print a label from SAP to the LP 2844-Z it will also print the ZPL code..
Which it shouldn't be doing.
Example:
^XA
^LH0,0^FS
^FO20,20^FDTEST TEST TEST^FS
^XZ
Should only be printing TEST TEST TEST at position 20,20.
Anybody ever seen this? ZPL code sent to a Zebra S600 printer prints the ZPL code as below.
^XA^MTT~SD24^PW606`r`n
^LH0,10^FO125,5^A0,50,60^FD3e-523-F2^FS`r`n
^XZ
instead of the intended
3e-523-F2
I saw a solution for another printer that the printer was in "line" mode instead of "page" mode but the S600 does not appear to have such a setting. The same code executes correctly on a Z6MPlus printer.
    Problem Solver:
  • 9 Answers
Hi..
Try using used generic text printer driver instead of windows driver for that model.or in the SAP environment try to used other driver..
Posted on Oct 31, 2008
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Confuse about which drivers need to install for my lp2824 plus? ZPL or EPL? What's the difference between those? When to use ZPL and when to use EPL?
EPL & ZPL are both printer script languages. If the label of your printer has the extension "Z" for ZPL (eg: 2844z-10320-0001) - then use the ZPL Driver.
If the product code has not the extension "Z" (eg: 2844-10320-0001) the unit has the EPL Engine.
Sep 09, 2011 | Zebra LP 2844 Thermal Label Printer
What is the difference between the Zebra LP 2844 Thermal Printer and the Zebra LP2844Z?
lp2844 use programming languages EPL2, Line Mode, lp2844 use ZPL II, ZPL (Zebra languages), both are Direct Thermal (don't use ribbon), not Thermal-Tranfer (use ribbon).
Nov 17, 2010 | Zebra LP 2844 Thermal Label Printer
How do I get Fedex label printer to print from other programs??
eack software have diferent wais to talk with the printer,
or send the comands to the printer (zpl files) and like this, he can send the printer configuration direcly, or can use setings from the driver.
if you go to Printer and Fax, right click on the printer driver, go to "properties" and print the test-page.
If print text plus the windows logo, that meens the printer is comunicate, now the rest is with the each software.
Nov 12, 2010 | Zebra LP 2844 Thermal Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Feb 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
your in line mode instead of page mode.
  1. Turn printer power off.
  2. Press and hold the feed key, then turn power back on.
  3. When light starts to flash, release finger from feed key.
  4. When light starts to flash again, press and hold the feed key until the light turns red (or amber), then release finger from feed key.
  5. Wait for light to turn solid and press feed key once.
  6. Check to make sure you are in the correct printer mode by printing a configuration label (Click here for configuration label example - Note item C).
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Can we use any commaon laguage for all Zebra printer.
Can you explain what is is you are trying to print on the label?
May 22, 2008 | Zebra LP 2844 Thermal Printer
Zebra Stripe S600 Thermal Label Printer Logo
462 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
