Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Westinghouse 40" with DVD Player will not turn on
My 40 inch TV with DVD Player won't come on. Time-Warner checked it out. The DVD will accept a DVD but it won't play.
Roger L. Trant
122 Frankfort Dr.
Dothan, Al 36305
Receipt ID# 5-8185-1468-0111-1313-0
VCD# 754-254-130 TM#xxxx6513
5 Suggested Answers
  • 4234 Answers
SOURCE: 40 in westinghouse LTV_40
The unit turning blue is usually an indication that the video signal has been lost. After that, the turning to black can be a screen saving mode to prevent any burnin on the LCP panel. When this occurs, try changing channels to see if the black wakes up to blue again. This sounds like an internal processing or connection issue. I haven't worked on Westinghouse sets myself, but in general LCDs sometimes can get a bit finicky. Is this unit still under warranty? If not, try opening up the back and reseating all of the cables and connectors. Any type of connection problem especially in the data cables can cause odd behavior like this.
Keep us posted on your progress.
Dan
Posted on Jul 18, 2008
  • 105 Answers
SOURCE: I have a 32
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Posted on Jun 23, 2009
  • 20 Answers
SOURCE: Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Posted on Jun 03, 2010
  • 20 Answers
SOURCE: I get no picture ...tv turns on bulbs are working
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for other reasons. Simple repair for any body with a Philips screwdriver. NO special tools needed.
GBC_CMC@yahoo.com
cyberfast
  • 155 Answers
SOURCE: westinghouse 32 inch screen goes blank
I had the same problem and changed the power supply all fixed. Power supply part number is DPS-210EP-2C and can be bought at http://www.moduslinkptstvboards.com/DPS-210EP-2C-P9987.aspx for around 60 dollars.
Posted on Dec 16, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
5 yr old Westinghouse TV w built in DVD player. DVD player won't play. Tried several different movies, none will play.
First thing I would check is that you are playing regular DVDS and not BluRay. Your TV may be old enough not to accept BluRay. If it doesn't work with a regular DVD then you most likely have a bad reader which can be replaced but you will have to take the tv apart to get to it.
Dec 12, 2013 | Westinghouse Electric SK-32H570D 32 in....
My dvd disc won't go into the slot on my westinghouse tv even tho tv has been turned on
Are you sure you are installing it correctly? Try both sides and then see if it is accepted. If not, then the drive is bad
Oct 24, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
We have the 40 inch flat screen with built-in DVD player, and have been well satisfied until recently.The DVD player won't allow a disc to be inserted. Though it is empty, the mechanism seems stuck and...
That will be a lot of work since you will have to open up the TV and get access to the DVD drive assembly, then you will have to disassemble the DVD drive to find out where the problem is.
This is the reason I will never own TV with built-in DVD, you will not have the TV while the whole TV is being repair due to fail DVD drive.
The repair can be from $150 and up plus parts.
You will be better off buying an external DVD player.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jun 26, 2011 | Westinghouse SK-40H520S 40 in. LCD TV
Oct 01, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
I get no picture ...tv turns on bulbs are working but I get no pic with tv or dvd and I cant see the menu or any of its properties .... but I do get sound, Thanks. The lcd tv is a westinghouse 40 inch dvd...
GBC_CMC@yahoo.com
Jul 11, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
May 31, 2009 | iLO 3200 32 in. LCD Television
Westinghouse TV
Hi Patty Jo,
I would suggest calling 1-888-Best Buy™ or 1-866-287-5555 for Westinghouse Support. Typically televisions become an in-home serviceable item near the 25-40 inch range.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 11, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
DVD trying to eject
I just took my West. DVD 40" apart
Very cheap DVD player inside.
Fixed one problem - the felt glued down to inside of DVD player to keep DVD from getting scracthed when inserted inside the player came off and was binding DVD - this may cause DVd to want to eject - I am calling Westinghouse to see if they will send me a new DVD player to install.
DVD has gotten louder over the past few of it's 20 month life as well - to an unacceptable level.
Mike
Mar 04, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
Televison & Video Logo
70 people viewed this question
Top Westinghouse Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
