Question about Cuisinart DLC-8S Pro Custom Food Processor
Dishwasher safe? are the plastic parts dishwasher safe?
  • 8,596 Answers
I would not reccomend it. The water, soap etc is safe, but the heat drying process risks melting parts, and they are surprisingly expensive to replace for being plastic.
-Tha Mp3 Doctor
Posted on Dec 09, 2008
The metal attachments oxidized. How do I remove the oxidation and is it still safe to use?
dishwasher powders/ detergents are high in alkaline with high PH values
that reacts with some metals or metal based products so any shiny aluminium finishes will be grey
it is a chemical reaction and will not be removable by washing or polishing
It will not look good but will cause not other problems
May 08, 2016 | Food Processors
The lid of my EP91 quad blade is broken
Hi Rosa
Depending on the severity of the broken lid....
I fix a lot of plastic items with either super glue or 2 part epoxy resin.
Then for reinforcement at the edges. I take a 2cm (aprox) piece of thin wire. Like a staple. Then heat it with the soldering iron. sliding back and forth until the wire is embedded into the plastic. even slightly covered over.
This often makes a cracked piece of plastic quite strong.
It may not look great but it might hold you over till you find a replacement
Good Luck
Here are some ideas....
Repairing plastic parts
How to Fix Broken or Cracked Plastic or Weld Plastic
Mar 16, 2016 | Euro-Pro EP91 Quad-Blade Food Processor
In need of Bowl and blade
GENERAL ELECTRIC FOOD PROCESSOR MODEL 106622F WORK BOWL
I was able to locate a bowl for the 106622F processor on E -Bay. You may be able to find a blade on E-Bay. From what I gather, there is no source for replacement parts, other than used parts. I hope this helps ! Good Luck....
Mar 31, 2014 | GE 106622F Food Processor
I have a Moulinex Ovatio 2 food processor. it looks as though the handle to the processing bowl can be removed...but I just cant work out how! It needs cleaning as the design of the handle lets water and...
It is safe to remove the white part - I just did it. Lever it off with a knife at the bottom then two clear plastic parts and the spring can be removed. Just don't lose the spring!
Aug 22, 2011 | Food Processors
Do you know where I could get a manual on Magic Bullet MB1001?
If you go on the website, http://www.buythebullet.com/ , they don't have a manual, but they do have recipes which not only tell you the ingredients to use, but how to use the machine to make them.
All the pieces except for the base are dishwasher safe and all the cups and lids (not the blades) are microwave safe.
Hope this helps!
Aug 30, 2009 | As Seen On TV Magic Bullet Food Processor
I have a kitchenaid food processor and the bowl is tightly set on the right side of center. I can't straighten it out and when I try to move it, it sounds like I'm cracking plastic. It won't run! Any...
Items required:
-dishwasher
-detergent
-lemonade or other citric liquid
-poochy
-skillz
Step 1:
gently position poochy around tube in center of bowl. Fill halfway with lemonade or other citric liquid.
Step 2: Put lid of processor on and put entire unit in dishwasher. Turn on power scrub cycle.
The dishwashing cycle will help the citric acid to activate the poochy.
Step 3: Use skillz to wriggle the bowl off the processor. Empty out poochy remains.
Congratulations! YOU'VE GOT SKILLZ!
Jun 08, 2009 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Jammed cutting blade in cuisinart tube
Try immersing the tube in super hot water. The plastic might expand just enough to let you slip out the blade. Since the tube is dishwasher safe, there should be no harm. A little soap in the water might help it slip out.
Jan 29, 2009 | Cuisinart DLC-5 Food Processor
Dishwasher destroyed bowl
A quick Google search using the term "braun K600 spares site:au" reveals an internet trader in Victoria who might stock what you're after. A.
May 13, 2007 | Braun K 600 CombiMax Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
65 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
