Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chain brake
Installed new chain blade on Husqvaran 51 and forgot to release chain brake. Can't put back cover because the brake tension won't allow it to fit over brake
  • seqer Oct 28, 2008
    pulled the brake apart and cannot find a way to release brake
Simplest solution can be found at http://www.youtube.com/watch?v=3__b2IYulgc
Posted on Feb 15, 2012
  • 45 Answers
You'll have to release the brake with the cover off the saw. You just need to find a way to brace it well enough.
If you really can't do this, then it suggests your chainbrake is faulty, of ath the very least not adjusted right.
Posted on Sep 27, 2008
  • Geoffrey Stoner
    Geoffrey Stoner Jan 09, 2011
    remove the blade and bar first, then put the cover back on then align up the 3 prongs on the saw with the chain brake, hold down the cover firmly, with your knee if necessary, reset the chain brake,
Husqvarna 240e
Pull the chain brake handle back to release the tension off the brake band and it will come right off..
Apr 29, 2013 | Husqvarna Garden
HUSQVARNA MODEL 435 CHAIN SAW.....BRAND NEW IN JUNE...NEVER USED....WITH BLADE, CHAIN, AND SIDE COVER (TENSIONER ASSY) REMOVED, IT RUNS FINE......WHEN CHAIN BAR , CHAIN, AND COVER ARE REINSTALLED AND...
There is a number of ways to re load the brake, you can either remove the clutch and sprocket, the brake will then go back onto the saw enabling you to use the hand guard on the saw to load the brake ( to remove the clutch, there are two cut a ways in the clutch centre designed to enter a flat screw driver into, then strike with a suitable hammer to remove, it is a left hand thread ) or you can remove the hand guard from the saw and use this as a tool to re load the brake, or you can clamp the cover in a vice ( be carefull not to damage the cover ) then use a strudy pair of pliers or grips in the three legged loading mechanism and turn it to load the brake.
Dec 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you put the chain back on the track of a Husqvqrna e series 235 chain saw.
You need to make sure the blade is not damaged. You need to release the chain tension screw, most cases; you turn in counter clock wise to release the tension rod. Do it in the reverse when you reinstall chain to tighten it back up to operating conditions.
Aug 25, 2011 | Husqvarna 450 e-series 18" Chain Saw
Took off cover to put chain on and can't get the cover back on the brake band doesn't sit right
You need to release the brake mechanism in the cover so that the brake band will expand enough to pass over the clutch drum. You should have released the chain brake before removing the cover, but that doesn't help now. Use a wide heavy screwdriver to release the mechanism. Hope this helps!
Nov 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
On my saw when I changed the chain out, the cover will not go back on over the clutch correctly.. The cover has a ring in it that is supposed to go over the clutch but does not fit correctly, What am I...
You should have released the chain brake before taking things apart--it will be necessary to move the brake coupling in the cover with a wide blade, square shanked screwdriver and a wrench that fits the square shank of the screwdriver. It should make a 'snap' noise when fully released and the brake ring will have expanded to fit over the clutch hub. Hope this helps!
Oct 18, 2010 | Husqvarna Chain Saw 20" Bar
Husq 455 rancher chain saw. the chain locking spring in the cover is in the lock position and will not mount on the saw. how do i release the spring tension?
you should be able to release it with a flat screwdriver. you should see something that looks like a wheel where the chain brake locks to the brake handle when you put the cover back on. you should be able to twist that wheel and unlock it that way.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cant get the cover back on chainsaw
The chain brake should have been released before removing the cover. You will have to release it with a large flat-blade screwdriver in the connector that runs the brake from the control handle. Hope this helps!
Jun 04, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 445 gas powered chain saw blade cover stuck
the only way to get the cover back on that i have found is to take the clutch drum off,after the drum is off you reinstall the cover,pull the brake back to the of possition.take the cover back off,reinstall the drum,put cover back on.it's a real pain to do it this way but i've never figured out any other way.husqvarna doesn't know any other way either.hope this helps,let me know
Apr 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Change blade on rancher 455
the easiest way i have found to put that cover on is to remove the clutch drum,once you have the drum off you can put on the side cover and release the brake.once the brake is released you reinstall the clutch drum.let me know
Mar 26, 2009 | Husqvarna Chain Saw 20" Bar
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
978 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
