Rear projection the color is not as strong as once new
  • jlm197399 Sep 18, 2008
    bought in 2000 model 9p5034c103 philips magnavox
I have a philips model 9p5034c103 do you know the lamp i need
Posted on Mar 02, 2010
  • 10,594 Answers
If its 2-3 years old model, then you need to service it and clean its rear mirror, front screen from inside tv and CRTs lenses.
you can do this by opening its back cover. if you post its model and brand, would be fine to help you in better way.
Posted on Sep 18, 2008
  • Shahid Electronics
    Shahid Electronics Sep 18, 2008
    Its 8 years old model and I'm sure it needs service.
    Unplug tv from AC outlet and open its back cover to get access inside tv. just clean the dust inside with air blower and then use humid cloth to wipe off dust, if any.
    Don't touch or unplug any board, if you have no knowledge of electronics or tv repair.
My red color is not coming in very good. i think i need to replace the bulb. how can i get a replacement bulb?
Hi Misty,
I would reset or zero out all the colour/ contrast settings first.
You can access all these via the menu on the remote.
If the reds still seem a bit weak, you can purchase new lamps on the internet. Depending on how old the TV is, a new LED flat screen might be the go. The picture difference from rear projection to LED panel is significant.
I would strongly suggest you do not replace the lamp yourself, there are dangerous voltages inside the TV cabinet.
Also, if one lamp is weak there is a good chance the others will fail soon. If it has done more than 5000 hours, time for a new TV.
Oct 20, 2013 | Sony KP-65WS500 65" Rear Projection...
Red color gone on LG PF60 A30 rear projection TV
If you would tap and get it back it would strongly suggest that you have a connections problem somewhere. Bad connector or aged solder joint that gave out. Be careful because there is a lot of voltage in TVs but you are going to have to do some jiggling to find the weak joint and repair it. Worst case is you have a bad video card and those can be tough to find for older TVs.
Oct 05, 2012 | LG RU-52SZ30 52" Rear Projection...
Color wheel for ws55313
Model indicated here DOES NOT HAVE A COLOR WHEEL- so you might want to enter customer menu and call up CONVERGENCE-THEN advanced convergence---a grid of yellow lines should appear----are they showing blue or red skewed etc?
Other is to look with color off to see if black and white screen or not?
Jun 14, 2012 | Mitsubishi WS-55313 55" Rear Projection...
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Very strong noise
Sounds like the color wheel is bad.It is a multi-colored disc that is spun by a motor at very high speed next to the lamp to produce the different colors in your video. The part can cost somewhere between $50-150 + labor if a tech fixes it.
Apr 30, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
COLOR SHADOW
that is called a magnet effect it means u have a strong current some were do u have a cd player or speakers to close surround sound to close if so move them away till it fades
Jul 05, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Changing channels,real strong red color on screen
Replace the SSB part number 310432716308 thatb is the video processor.
May 10, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
