I have installed a new ink cartdrige and now my printer will not print
    Sergeant:
  • 399 Answers
Check whether the usb connections are properly inserted in printer and pc.
for any further queries feel free to ask.
thanks
Posted on Sep 18, 2008
Error message "no ink cartdrige"
reseat the ink cartdrige
ink cartdrige is bad or malfunction, replace the ink cartdrige
May 14, 2011 | Office Equipment & Supplies
All new cartdriges but magenta wont print at all after 4 head cleans and nozzle check. not expired
Check if inks were original or refilled
Original/Genuine inks are best recommended
Restart the printer
Reset the printer
Do some alignment on the printer
remove/reseat the inks
check the ink levels
possible ink issue it can be replaced if it is in warranty
Hope I help you a bit.
Your's Truly,
Christian from HP
Mar 27, 2011 | Epson Stylus R250 InkJet Photo Printer
I purchased ink that stated that it was compatible with my R220. It worked fine for a short while and then I got a message that the cartridges were "not compatible" and it stopped printing. I...
possibly because you bought non-original cartridge (it does not recognize the printer). Try to mount the old ones again and see if you recognize the same message persists imprimanta.Daca ignorance of cartridges means that problem is another possible carrier on the outer cartusele.If with the old cartdriges you have another message then it is a problem with the new purchased cartdriges and should replace them
Feb 24, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink Problems. is only printing with yellow ink
You may need to replace the Print Head or Purge Unit.
May 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
My printer is not printing..page comes out blank. inside, all the lights are flashing on the ink cartridges...any ideas what's wrong? thanks
this message means that the cartdriges are empty...
if you have bought new cardridges and lights still flash then the printer just dont recognize them right.
possible cause 1:
dirty cartdrige (or printhead) chip contacts > clean them with alcohol and cotton (switch printer off first).
see the chips in this photo:
https://secure.datatekusa.com/images/canon%20PGI5.CLI8%20refillable%20cartridge.jpg
possible cause 2:
bad printer controller: the chip in the printer that communicates with the cartdriges is gone mad... take the printer to service...
all the above are valid assuming you bought original cartdriges if not then do so...
Sep 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Remove (r) color cartridge out of ink
I'm sorry, there is no way to bypass this. You must have a cartridge that is not empty in the R slot in order for that particular model of printer to work.
Jun 04, 2009 | Dell 946 All-In-One InkJet Printer
Cartdrige
go to hp.com search model number then download driver.it 1 hr to download this driver..
Feb 05, 2008 | HP PSC 1410v All-in-One Printer
35 people viewed this question
jasbo
jasbo
