Question about Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw
Samsung shr 1040
I purchased it used and after the system initializes all I get is a screen that
says SYSTEM STANDBY
Thanks
Michael
jordan431@gmail.com
  • Anonymous Nov 18, 2008
    System initializes, then goes to "System Standby". No buttons function on unit, including "menu". Power light is on.
  • Ken Eastham
    Ken Eastham Jun 10, 2014
    I am experiencing the same problem? Was a satisfactory solution discovered?
  • 80 Answers
Try resetting the system and reprogramming.
if that does not work you may need to have it repaired.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Posted on Sep 07, 2009
I forgot my password and I cannot do anything. What is the solution? SHR-1040 DVR security system.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Jul 09, 2009 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Samsung shr-1040
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
Mode Key + CH 2
default value.
mj
Apr 28, 2009 | Samsung 4 Channel Dvr
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
May 15, 2008 | Samsung 4 Channel Dvr
Samsung SHR-1040 DVR
try resetting the system and reprogramming if that does not work you may nee to find a factory authorized repair facility in your area.
Mode Key + CH 2
default value.
mj
Feb 10, 2008 | Samsung 4 Channel Dvr
Samsung SMO 151QN need to purchase the proper recorder for this unit
We're using a Samsung SHR-1040 recorder with
a Samsung SMO 151 QN. It has more options than
needed ( has it's own camera ports) but it's cost
effective and records well. It has been in use since
July 2007.
Nov 26, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw Logo
366 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
