Question about IBM TravelStar 4GN 4.32 GB Hard Drive
A "Beep, Beep, Beep" Noise
I have tried two ways of connecting this HDD & both ways I get the "Beep, Beep, Beep" tone that repeats either 4 or 5 times. Is this HDD shot? Or is there something I'm doing wrong?  I'm new to 2.5" HDD"s.  Please help!!!
Thanks, grandpappyhappy
  • Crazyjolin Oct 24, 2008
    I have the exact same problem, it was working untill just recently.
After further research, I TOSSED IT IN THE TRASH!
Posted on Jun 12, 2009
SOURCE:
What does reorder tone mean?
A busy tone (Busy Signal) and a reorder tone are two similar on-off repeating tones that differ in the spped that they beep on and off. Some lay terms for a reorder tone is a Fast Busy tone. Both types of tones use two different frequency tones simultaneously, 480 and 620 Hz, for the beep sound. Busy tones are a half second of tone and a half second of silence, repeated. Today's reorder tone is a quarter second of tone and a quarter second of silence repeated, twice as fast as a busy; a long time ago the cadence was a little different.
May 05, 2014 | Panasonic KXDT343 Phone
How do i make my audiovox walkie talkie stop making a beep noise
In the "settings" there should be an option to turn off "beeps" or "tones" or "notifications", something to that effect.
Feb 16, 2014 | Radio Communications
Digital tone not bringing up repeater
Without knowing the model of radio or the specific repeater you are trying to access, the only things I can suggest are 1) check to make sure your radio is setup for duplex operation, 2) check to make sure the offset is correct for the repeater, 3) make sure you are in tone mode (not tone squelch mode) and that the tone is correct for the repeater, 4) if the repeater is still not coming up, listen for a while to see if others can access it. If you don't hear other traffic on the repeater there is a possibility that it is down.
Other information that would help get you an answer would be the make / model of the radio (you said Vertex but that could also mean Yaesu), and information on the repeater you are accessing (frequency, location, repeater callsign).
Dec 26, 2013 | Vertex Radio Communications
One short beep one long beep coming from hard drive
..as i know when HDD start beeping ( internal or portable ) that indicate problem with the Hard Drive (HDD)..so nothing you can do it by your self ..
..if the HDD is under warranty from factory you may take it to the store that you buy or nearest Western Digital distributor to claim the warranty...but if it doesn't in warranty..that's mean a problem why?
because if HDD start beeping like you have, the possibility to make it work again is almost impossible that mean you maybe lost the data that you save in this HDD..
Sep 01, 2012 | Western Digital Caviar Computers &...
One of my walky talkys(motorola T4500) makes an extra beeping noise whenever i turn it on. This noise also shortens up what people are saying before they finish talking. How do I fix that?
What you might be experiencing is the Talk Confirmation Tone aka Roger Beep. I have looked through the T4500 manual and do not see any instructions for turning it off, just that it is listed as a feature. However, something you might try is holding in the + (plus) button while turning on the radio and see if it disables the feature. This method is used on many of the other TalkAbout models.
If it is not the Roger Beep, it could be a low battery beep. But from your explanation it sounds more like a Roger Beep.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Best regards.
Aug 25, 2011 | Motorola Talkabout T4500 (7 Channels)...
When i plug in my lacei 500gb all i get beeping tone what is the problem where can i repair
Your HDD might having a problem,have you ever try another hard drive for a test? or trying to plug-in your hard drive to another computer?
Symptoms of hearing a beep or other extra noise is that;
* when your Hard drive fell or dropped on the ground
* spinning fast up and down
Chances to be recovered by;
* plugging in to another port
* format the Hard drive
Good Luck....
Jun 28, 2011 | Computers & Internet
My sony vaio desktop (model vgc-rb60g) powers on then gives a continuous high tone and nothing else. nothing sent to the screen.
I understood your problem.
it's a beep code. That beep code indicates the nature of the problem with your CPU.
these beep codes are different as per manufacturers see the booklet provided with your CPU which shows continuous beep indicating type of problem.
If further cause such a problem then you should remove all connection to HDD and RAM and re-connect it manually.
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 17, 2011 | Sony VAIO VGC-RB60G (027242690547) PC...
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
Latitude D600 beeps twice
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
Open Questions:
See all IBM TravelStar 4GN 4.32 GB Hard Drive Questions
IBM TravelStar 4GN 4.32 GB Hard Drive Logo
1,062 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
