Question about Dell Axim X30 Pocket PC
Backup battery give location for backup battery i can't fine it for the dell pocket pcaxim x30
  • 10,594 Answers
click THIS web link and see illustration of opening unit to see battery.
Posted on Sep 18, 2008
  • 2,794 Answers
Here you go:
http://www.suntekstore.com/1800mah-li-ion-battery---usb-charge-and-sync-cable-for-dell-axim-x3-x3i-x30.html
I checked on a Dell forum and these batteries will work. There just a little thicker.
    Sergeant:
  • 399 Answers
Its in the back of device a slight curved flap is given just lift that flap and its there.
  • masterexpert Sep 18, 2008
    for any further queries feel free to ask.
    thanks
Where is the backup battery
On the motherboard, at the bottom near the charging port. You will have to remove the motherboard completely to access it. Here is a good tutorial with pictures and all the information you need.
Dec 07, 2011 | Dell Axim X30 Pocket PC
I need a replacement screen for my Dell axim x30 pocket pc 2003 version. can you tell me where i can find one?
$23 with free shipping:
http://compare.ebay.com/like/280596977205?ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=212022785319&crlp=1_263602_304662&UA=%3F*F%3F&GUID=0221a2341240a02653554075feb032fd&itemid=280596977205&ff4=263602_304662
Feb 20, 2011 | Dell Axim X30 Pocket PC
My dell axim x30 backup battery needs replacing. Is this something I can do myself?
i believe if you are a bit of a hands on type of person you should be able to do this yourself.
but not without researching !
read this page, should tell you everything you need to know, from the perspective of someone who had to do the same changing of the CMOS battery.
http://www.mobilitysite.com/boards/x3-x3i-hardware-troubles/96005-x3-backup-battery-revealed.html
or read below:
quoted from: Tenc hi4U
DISCLAIMER : I take no responsibility for any damage you may cause to your Axim. The parts and proecedures described in this guide refelct my own experience with my own Backup Battery (BuB) in my girlfriend's Axim X3. Your mileage, parts, anbd experience may vary.
Tools needed for successful BuB replacement:
1. fine tip jeweler's screwdrivers (helpful if you slightly magnetize the tip)
2. Varta V20HR rechargeable NiMH battery
3. electrically conductive silver epoxy
4. strong needlenose pliers
5. electrical tape or heatshrink (razor blade or scissors to cut to shape)
But here it is step-by-step:
1. Pop little rubber caps from 4 corners of back covers. Disassemble Axim X3 with small jeweler's phillips head screqwdriver. Be sure to plave all parts in a plastic bag or other container (4 scres rear cover, 2 screws near port). Disconnect the ribbon connector towards the bottom of the PCB and the speaker wire (also on the lower portion of the PCB). Backup battery should be the green covered circular item under the pcb).
2. Locate backup battery, Cut away BuB cover, & CAREFULLY use strong needlenose pliers to grip and "roll" the leads off of BuB.Be very careful with the leads.
3. Mix dime sized batch of silver conductive epoxy (do NOT hot solder this battery, heat will lead to BuB damage and destroy lead connection to wire).
4. Apply epoxy to both sides (not too much)and afix respective leads to respective side (red lead goes to +, black lead goes to -). Secure connections with some type of clamp (I used a binder style paper clip, but a wooden close pin or something else that will hold the leads to the BuB while the epoxy cures (Mine took 24 hours to cure).
5. Recover new BuB with protective covering (I use electrical tape cut to the shape of the BuB. Covering WILL have to be form fitting to fit back into Axim BuB "slot".
6. Reassemble and charge Axim and charge.
Sep 07, 2009 | Dell Axim X30 Pocket PC
Axim x30 won't come up
The Dell Axim X30 be soft reset by pressing the "Reset" button (from the stylus tip) on the rear of the unit, below the battery.
If the Dell logo in blue background lights up and then goes off again, its probably the brightness setting of your unit. Once the device has started up, just press and hold the jog wheel (the volume wheel above the headphone jack on the left side of the PDA) and press the UP directional key in the front bottom of the PDA. Every press of the up key should brighten up the screen a bit.
If the above solution does not work, you probably might need to hard reset your device.
WARNING: A "hard" reset wipes the RAM and returns the Pocket PC to its factory defaults. You might (mostly) lose all your data if you perform a hard reset. Do not hard-reset your device without having a backup of your data.
The procedures for hard resetting your ppc is given in a very detailed steps in the following page:
http://www.pocketpccentral.net/help/dellx3reset.htm
Apr 24, 2009 | Dell Axim X30 Pocket PC
Dell axim x 30 backup battery wont work
--This is a suggestion. I can not be certain given I have not worked on this device. --
Sounds like the backup battery is dead and needs to be replaced.
Researched The battery, and it is a standard flat-cell available at Radio Shack.
Taking the device apart will void the warranty.
The device is assembled in a standard click-tab and possibly some small hidden screws.
A plastic screw-driver or non-marring wedge tool is best.
Simple work your way around its edges until a gap forms and gently feel towards a portion that will not separate. Get a tool in there and gently pry away from the device to disengage the clips, rinse and repeat.
Upon removing all the tabs, remove the back panel slowly to assure that there are no wires connected to the panel itself, you should see the battery.
Apr 14, 2009 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Fixing backup battery for axim 30
http://www.gethightech.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GHT&Category_Code=_x3_takeapart
step 10 is actually the lead to the backup battery. Follow the wires to find the battery.
Hope it helps.
Jun 03, 2008 | Dell Axim X30 Pocket PC
Battery problrm
u do one thing u change the battery first,,,else again it gives a problem then u must complaint 4 dat company
Dec 26, 2007 | Dell Axim X30 Pocket PC
Backup battery problem
Try this web site:http://www.pdasmart.com/aximpartscenterx3.htm?tp=CONTINUE+SHOPPING
Sep 04, 2007 | Dell Axim X30 Pocket PC
Dell Axim X30 Pocket PC Logo
161 people viewed this question
Alun Cox
