Black section starting from the top of screen
  • uakeaflys Sep 19, 2008
    The black streak is still there. I think it may be another problem.... probably equipment problem. Thank you for your help!
    Master:
  • 505 Answers
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple Repeat the above......
Regard; Aaron
Thanks for using Fixya.com
Posted on Sep 18, 2008
HOW DO YOU SPLIT THE CABINET ON TOSHIBA TV CT-90159
Pop off front speaker grille, there are 1/4" hex screws holding the screen on, and a connector that needs to be disconnected first. The 1/4" hex screws in the back and sides along the mid section also need to be removed, then the entire top lifts off - be careful, the screen separates from the black plastic part (you might want to lift off the front screen first, that way you can be sure you have all the screws removed.) There was the black power section that was screwed in that needed to be wiggled off first, then the top just slides off easily. Easy to clean and reinstall by putting the black part on first, then sliding the screen up, over, then down onto the black plastic part. Replace all screws and reconnect the connector.
Jun 21, 2012 | Toshiba 57H81 57" Rear Projection...
Lines on top of screen
Hi and welcome to FixYa,
Initially, sounds like a capacitor at the vertical section about to fail, leaking or blistered. Additionally, have seen some of these models suffers from vertical fault due to a defective capacitor in the power supply section or cold solder.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 03, 2008 | Televison & Video
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
ILO tv black screen on top black screen on bottom with only about a 4" picture screen in middle... can you help thanks jerry
Hello dacrewof6,
This sounds like your vertical section is malfunctioning. This can be caused by the vertical drive section which connects to the yoke transformers of your CRTs. I would suggest taking the set to a qualified repair shop and having them check the vertical section of the TV.
I hope this helps
Thank you,
Shuttle83
Sep 11, 2008 | Televison & Video
LG 45V model
hai dear, this problem is related s.m.p.s. section. so you can redry soldring at s.m.p.s. section and i hope this problem will solve
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Acer TV Plasma screen problem
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Televison & Video
Picture quality
your problem is in vertical section 1 check for proper supply. 2 some capacitor in that section is faulty. not a major problem. it is COMMON PROBLEM can be fixed easily.
Sep 24, 2007 | RCA F36650 36" TV
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
Sep 12, 2007 | Sony KV-32S42 32" TV
Televison & Video Logo
Top Televison & Video Experts
