Question about Sony SPP A973 Cordless Phone
Cordless phone doesn't work
I have S/C Invalid on my screen on my Sony cordless SPP-A972. How do I get it off?
  • 9 more comments
  • jsquier9927 Sep 18, 2008
    Charge the battery and try again didn't tell me a thing. I need more specific advice get rid of the S/C Invalid on my Sony cordless SPP-A972
    To Sam Anderson: The inside of my handset looks clean and normal. Is it time for a new phone?
    How do you re-register your handset to the base unit? I have set the security code to 20.
    S/C Invalid on display of my Sony SPP-A972 cordless phone. Solutions so far haven't helped.
    The security code is set at 20. You can't enter # plus the number of the handset when it doesn't work.
    Unpluging and disconnecting has been tried numerous times with no success.
    Nothing offered so far has helped. S/C Invalid on my handset is still there.(Sony cordless phone SPP-A972)
    S/C Invalid is still on my handset(Sony SPP-A972) If it helps the handset whines when I set it in the base.
    Nobodys getting back with me!
    Probably 5 years old?
    Nothing has worked! Sony cordless phone SPP-A972 has S/C Invalid on the screen. Handset doesn't work at all. If it helps it whines when you put the handset in the base unit.
I would recommend this manual, a previous posting gave a link to the manual for model A972, but this discussion pertains to model A973.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=SPPA973&LOC=3
I also have a model A973 with the "S/C Invalid" error. Nothing so far has worked. We bought it used for $4 yesterday. I have tried setting the security code as shown on page 41 of the manual (downloaded using the above Web address), but that section of the manual refers to the security code to access the mail boxes from a remote phone. The error on the handset is most likely referring to a different "Security Code" related to communication between the handset and the base unit--as other posts here have suggested.
Posted on Oct 05, 2008
    Master:
  • 441 Answers
Go to this page for the manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=SPPA972&LOC=3
Hope this help
search for security code
Posted on Sep 18, 2008
  • 4,472 Answers
How long have you owned the phone? Once I have the needed information I can recommend the best course of action. Please don't request more help/reject my help til I can properly assist you.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 18, 2008
    What was it you didn't like about my solution it is not economical to have the phone repaired and it should be replaced. I hope you will reconsider your rating and accept and rate accordingly. If you have any questions I would love to hear them. If you need any assistance in locating a proper replacement it will be no problem. Also have you replaced the battery with a new one?
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 18, 2008
    Though for the price of a battery your better off just getting a new phone.
    Thanks,
    Lee
    Brigadier General:
  • 5,158 Answers
S/C INVALID.
It means the security code is invalid. The phone & base are not talking to each other. do you have the manual for the phone.... check that the number you have i believe it was 20 is the same as the base. generally to reset the security code you just place the phone into the charger.... the base not the spare charger for a couple seconds... you will see the light on the base flicker. it should work then..... this can't be accomplished by using the spare charger if in fact there is a spare.
Robert
  • Roberta Smith
    Roberta Smith Sep 18, 2008
    further to this.... did the phone fail during a call ?
    Robert
    Master:
  • 505 Answers
Un plug power and all battery's to phone and un plug the phone dock station then reconnect all the power.... see how that go's
  • 10,594 Answers
I think its miss match case of Tx and Rx frequencies of base unit and hand set. You can change / select different channel for communication of both units to resolve this problem.
Need further help, please give more details of phone problem.
  • Shahid Electronics
    Shahid Electronics Sep 18, 2008
    well, problem has not been resolved yet, means its time to get new phone set.
    as I told you in my 1st post, its problem of Rx and Tx section in unit. Repair cost will be more then phone worth. better to buy new phone.
    Thank you.
    President:
  • 1,952 Answers
I think I have found the solution. If you look under the base you will see two little holes. In the handset under the battery there is a plastic sticker. Pop it off and you will find the same two little holes. When you look in the hole you will see small metal contacts.
I took the handset apart to see what they were. Stamped on the board it said TX & RX.
I am yet to perform this test as I have not had the time but my hypothesis is that these contacts are the key to resync the system.
I would have to rig up a pair of wires, use an external power supply to power the handset up because you can't access the connections with the battery in place & see if by joining the two together via a wire would do the trick. Now I would guess you take the RX from to base to the TX of the handset & vice versa.
  • mohammed marika thambi
    mohammed marika thambi Sep 18, 2008
    The procedure for setting the security code is on page 41 of the SPP-A973's user manual. Follow them and you should be all set.
    Have you tried the security code (19)
  • Sony Master
  • 6,487 Answers
That erro means that the handset and base station are not communicating, you need to re-register the handset to the base station in order for it to work and make sure you use the proper security code....
Hope that helps.............
  • Mark Gil
    Mark Gil Sep 18, 2008
    If you have the user manual look there for the option to reset the handset and re-register it back to the base.....
    Sergeant:
  • 399 Answers
Remove the battery and reinsert after some time then charge the phone in off mode and then on the phone , and you will be able to off the Sony cordless SPP-A972.
for any further queries feel free to ask.
thanks
  • masterexpert Sep 18, 2008
    no its not the time for new handset , as this is a repairable problem.so dont worry try the solutions given by all the experts it will help.
    if it does not solve take it to the technician it will be repaired with very negligible cost.
    thanks.
    read this for more help to you to solve your problem which others are facing and what they have done to make it clear click the link below.just click on the link and the page will open just go through it
    http://www.agoraquest.com/viewtopic.php?...
    thanks.
    Genius:
  • 1,665 Answers
Have a look at fixya on line manual for your set. Follow instructions to use and see troubleshooting tips.
http://www.fixya.com/support/p121317-sony_spp_a972_cordless_phone_spp_a972/manual-16138
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Sep 18, 2008
    Read carefully troubleshooting guide on page 74.
    Genius:
  • 1,550 Answers
You may have corrosion (caused by the chemical reaction of the water) on the
keys and/or in the circuits which may have caused damage.
You'll need to check the handset (the unit you hold in your hand) for internal
damage.
A visual inspection (once inside the device) should be enough to show you where
the trouble spots are.
You have to thoroughly wipe and dry the areas. then there is retouching of
solder connections, followed by troubleshooting procedures of the handset's
portion of the DC power supply and the other circuits.
This repair is generally fairly intricate to do (moderate to difficult) and
will take you at least 2 hours + to diagnose and/or correct.
Source:fixya.com
SAM ANDERSON
    Scholar:
  • 163 Answers
Make sure it is fully charged and then try again.
  • Elias Mavropoulos
    Elias Mavropoulos Sep 18, 2008
    It seems the phone does not accept your
    remote ID code (security code).
    1.Make sure the remote ID code (security code) is correct.
    2.Make sure you entered the remote ID code (securitycode) within two seconds after you‘ve entered (#).
I'm trying to locate the instruction manual for sony spp - a972
Dec 16, 2010 | Sony SPP A972 Cordless Phone
My Sony cordless handset doesn't work and displays "S/C Invalid".
  1. Place the handset in the base.
  2. Unplug the AC power adapter from the telephone base.
  3. Disconnect all the telephone lines from the telephone base.
  4. Allow the telephone base to remain without power for 1 minute.
  5. Connect all the telephone lines to the telephone base.
  6. Plug the AC power adapter back into the telephone base.
Aug 31, 2010 | Sony SPP A973 Cordless Phone
Problem with hearing
Try moving around while you are on call or moving close to the base.Make sure your battery is fully charged.And also try adjusting the volume of the earpiece
Mar 25, 2010 | Sony SPP A972 Cordless Phone
Buttons on Sony Spp-A2470 cordless phone are sticking.
There are liquid repair kits available to restore the carbon buttons on the back of each key How to repair remote control Tutorial ReplacementRemotes com The video explains it and is also a source for the necessary repair kit.
Apr 25, 2009 | Sony SPP A2470 Cordless Phone (SPP-A2470)
S/C invalid on my cordless phone screen (Sony SPP-A972
Most likely water has gotten into the back of the handset and shorted the handset.
AL
Sep 18, 2008 | Sony SPP A973 Cordless Phone
"S/C Invalid!" on display screenTxPrw:_ Ch:05
S/C Invalid on screen How do I get it off?
Dec 02, 2007 | Sony SPP A973 Cordless Phone
Sony spp-900 cordless phone
Go to the sony website and down load the user manual at this link. http://esupport.sony.com/US/perl/model-documents.pl?mdl=SPP900®ion_id=1
Jun 28, 2007 | Sony SPP 900 Cordless Phone (SPP-900)
Sony SPP A973 Cordless Phone Logo
290 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
