Question about Lexmark T644 Laser Printer
Printing envelopes i need to print 1,000 envelopes with my address in both places but when i try to print from works it will only print one at a time it beeps and i have to press continue
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have Microsoft Word?
    Problem Solver:
  • 13 Answers
You have to either use the MP Feeder or an Envelope Feeder. When you send the job to the "Manual Envelope" option, it will beep and prompt before each envelope is printed. Same will happen when you use the "Manual Paper" option.
You will have a hard time printing 1000 envelopes. The printer will print a rated engine speeed for the first 6-10...After that, the narrow media sensor will force the printer to slow down and you will proabably get 5-6 envelopes printed per minute.
Posted on Feb 06, 2009
Trying to center address on 7.875Wx5.5 envelope an run a merge
if you are using word to type the address use the tool bar to center it on the page
then when you go to print , check the preview to see where it will be printed
set the printer properties to envelope and use any old envelope to see where it prints
Nov 15, 2017 | HP DeskJet F380 All-In-One Printer
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
How do I print an envelope with my MFC 240C?
Printing envelopes is tricky. In the MFC-240C, you have to place them face down (with the flap side facing up), and it's best to load one at a time because sometimes the printer has problems pulling it when there is a stack of envelopes in the paper tray.
Make sure the fences are snug against the envelope when you load it. If you get a lot of jamming when trying to feed envelopes, you may have to run it with the flap open -- sometimes the closed flap sticks up just a bit and gets caught as the envelope is fed through the machine.
To orient the addresses correctly on the envelope, you'll need to use the correct settings, depending on which program you're printing from. In Microsoft Word 2003, for example, there is an Envelopes and Labels option under the Tools menu (click on the Letters and Mailing submenu) that you can use to enter the addresses and make sure they line up.
Apr 15, 2010 | Brother MFC 240C All-In-One InkJet Printer
My HL 2040 How do I print an address on an
You have to select envelope size in your word program, and then place envelopes one at a time in the slot in the front door.
Jul 14, 2009 | Office Equipment & Supplies
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
Can't print envelopes
is this the first time you use word ?
if it is any of the newer version 2003, 2007. the printing of envelope is as follow:
open the word, elect tools>>envelopes and labels. type in the delivery address and return address. click add to document.
completed you letter.
whenyou want ot pin the envelope, hig light the delivery address on the document, file, pirnt, type in 0 (zero) in the pages box under the page range (in the middle of the popup, under the "curent page button).
Mar 26, 2009 | Samsung ML-2510 Laser Printer
My HP 1350 will not print cards/envelopes from the right side of the printer. They have to be loaded on the right but the printer keeps printing in the center.
Printing envelopes with an HP 1350:
If you use MS Word, select ENVELOPES. When address window appears, select OPTIONS on right > select PRINTING OPTIONS > select FEED METHOD option on far right (envelope placed on right of tray face down); select FACE DOWN; select FEED FROM UPPER TRAY. The only problem I have with this is that the address prints off in the lower quarter of the envelope rather than in the center of the envelope as we would write it manually. I am currently working on solving that problem.
Mar 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Printing on a #10 envelope
Go into your Word Document and print from "Tools" then "Letters and Mailings" and click on Envelopes and Labels. Sometime the perimeter isn't defined and it is on there but it's outside the scope of your envelope, especially if the return address isn't in the correct place also. You may even be able to correct it where you are by decreasing the "window" of your typing space, it's just too large.
Jan 17, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Printer keeps printing the same address on envelope
You need to restart the printer some times happens if the buffer gets full.
Dec 15, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Printing greetings cards and envelopes
At the moment it is printing both sides of Greetings cards, but this printer appears to be very sensitive with regards to placng card in the exact position in the paper tray.
Why it will not print envelopes without smudging I still don't know, so I shall just have to write address by hand after I place graphic on the envelope
This 5300 was a Christmas gift from my wife and if I could afford to change it I would. The performance is very dissapointing
Kindest Regards
David Gray
Mar 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark T644 Laser Printer Logo
495 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
