You could have a charging port issue, you may need to install a new one into the phone or order a backup battery plus a battery charger, interchange them as needed.
With the phone OFF and BATTERY OUT.
BACK COVER OFF.
Pass a vacuum cleaner gently over the MIC for two minutes.
A small paper clip can be use to assist removal of dust and dirt.
DO NOT PUSH paper clip or any object inside.
Inspect for dis-mounted item inside the phone.
Re-insert battery and cover.
LG Env VX 9900 is the best music and simple video phone. Do this clean up around the lower MIC portion will keep the sound quality is check.
really yes! this phone is a lucky one, because this is a refurbished LG enV VX-9900 phone ready for activation on the Verizon Wireless network ,their will be no need of sos code for activation
Click on this link Lg vx 9900 User Manual or
http://docs.phonedog.com/lg-env-vx-9900-manual-4316.pdf
to download the user manual for your Lg Mobile. This is a direct link, download will begin once you click the link. The file is in pdf format, so you'll need a pdf reader to read the manual. If you need one (click here to download adobe pdf reader)
As long as you know your security code you can retreive your lock code. On the Lotus dial ##3282# scroll down to Advanced, choose View, then scroll down to option 5 which should be the Lock Code and select it. You will need to enter your security code here which typically is 6 zeros.
Type in that last four digits of your phone number. If that doesn't work, type in any codes that you have ever set on that phone. That includes the voicemail code. Try that, too, cuz you never know. If that doesn't work, try the pound key or the star.
