Question about Lexmark Office Equipment & Supplies
My computer cant connect to my printer,. printer wont print or scan again.
    Sergeant:
  • 399 Answers
Check whether the usb connections are properly attached to the computer and printer.
for any further queries feel free to ask.
thanks
Posted on Sep 18, 2008
Scanner & Printer Features are missing in the system setting.
Print scan card not in unit? ( a SD card on left rear under a cover)
Feb 05, 2014 | Ricoh Aficio Mp171spf Copier,Fax,Net...
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
My printer is printing but i cant scan my documents - no compatible printer installed
Make sure the Lexmark OCR scan software (used to scan documents, convert into PDF file or create multiple pages into 1 file). The software is available on the installation disc that came with the printer.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your problem, your rating will be greatly appreciated. Thanks.
Oct 20, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Cant scan on my lexmark x4690 it does print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB-connected). Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB-connected). Then try to print again once the computer fully recognizes the USB connection.
Sep 12, 2011 | Lexmark X4690 Wireless InkJet Printer
I cant scan my picture at the scanner
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 07, 2011 | Lexmark X2600 InkJet Printer
Have the printer networked, and cant get it to scan. I am able to print to the print side, but cant scan. HP2320nfi
You can get it to scan.. only in the computer where it is locally connected. Scan will not be available for sharing in the network.
On the computer where it is locally connected, use the scan option in the Control Panel if the Scan buttons in printer is not working.
Oct 04, 2010 | HP Office Equipment & Supplies
Can't Scan with MX310 hooked up to Time Capsule
If you mean you connected it to the airport, that only supporting printing, not scanning. Have to plug it into the computer.
Jul 02, 2008 | Canon PIXMA MX310 All-In-One Printer
I cant scan
You have to connect the mfc directly to a USB port of your computer. DO NOT use a hub.
The mfc uses the XP buil-in scan driver.
Did you install the whole mfl-pro suite? Use paperport to do scanning from your pc.
Jan 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Feb 23, 2007 | HP PSC 1510 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
