Question about Tomtom ONE 3rd Edition GPS
Unit charges on computer but not on car chargers
Unit charges just fine on computer usb cable but will not turn on green light or charge off of my tomtom charger for car or others that are known good, what is the difference here between the two sources that one will work and the other will not, I notice that it once in the beginning did work in car, updating the map affect the circuit>?
what could cause this and what is the remedy.?
  • DawgInIndy Feb 03, 2009
    I have the same problem. Car charger used to work. Now no car charger will work, while the computer USB works fine.
  • Anonymous Feb 16, 2009
    Same issue will not charge in the car
  • 3 Answers
Hi
Check the fuse on the car charger. Try another working car charger, from friend to see if that works for you.
Posted on Nov 10, 2008
As per the Tom Tom Experts hte computer USB is meant to charge and the Car charger is only used to maintain the already existing charge. Hope this works
Posted on Sep 19, 2008
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
How to charge a psp with usb cable while it's dead
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
May 24, 2012 | Sony PlayStation Portable (PSP) Console
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My Dell Streak 7 Tablet will not charge. When the charger is plugged in, it does nothing. No light at all. When the power button is pressed, the front lights come on momentarily and then the charging light...
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Aug 11, 2011 | Dell Streak 7 Tablet Android
Unit will not power on.
its probably not the battery, your gps should run even without a battery if the power port/circuit is ok. unfortunately this is a common problem that the usb port gets damaged with this and many other model of magellans gps systems.
if you had it plugged in to the car charger, make sure the green light is on while charging, if its not, you might have a blown fuse in the charger or the fuse for the cigarette adapter in the car.
if the green light is on, try letting it on for a few hours, then try and turn it on. if and when it turns on, you can verify if its charging by going to the system settings then the power option. the battery bar should turn green and move from right to left if its charging. if the battery is slightly low but the bar is not moving left to right, then its not charging.
you can check the charging by using the usb cable provided with your unit and hook it up to your computer to verify if its charging. but i suspect it has a bad power port (usb connector)
i hate to be the barer of bad news, because rarely do i get a good rating for being the barer of bad news, but hopefully you just have a bad charger or a blown fuse in your adapter or car.
good luck
bill
Oct 19, 2009 | GPS
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
S9 headset
I just hooked it up with a usb sync cable to my computer. It was installed and ready to use and the charging light came on. Seems like it is charging as the led went from red to yellow, and it does turn on now. However, it still does not work with the usb cable plugged into a wall charger. If this solution works for others having the same issue kindly post your results.
Sep 16, 2008 | Motorola Mobility S9 Headphones
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
My phone will not show it charging and will not turn on, red light flashing
i cant charge my phone using a charger
when i put the head phones in the same port, my phone does not pick up the signal
BUT when i connect my phone to the pc using a usb cable, it charges fine and i can transfer data
WHAT IS WRONG WITH MY PHONE????
Apr 19, 2008 | Cell Phones
Tomtom ONE 3rd Edition GPS Logo
169 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
