Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv green light flashes but wont turn on
We have a sony trinitron tv that the green light flashes on and we dont get a picture, it sounds like its turning on but then flashes
  • Sony Master
  • 5,568 Answers
If there is no pattern to the flashes, it is just cycling, not producing an error code.
This behavior may be the power supply but that may not be the problem.
Modern power supplies are designed to shut down if the current drawn exceeds the design level which indicates that something the supply services has died.
For gear made in the period of 2003-2006 and stock that is still on hand from that period, may contain electrolytic capacitors that have defective electrolyte, a chemical used in the manufacture of higher value capacitors.
The electrolyte was made from a stolen Japanese formula and improperly cloned in . . . where else? China.
There are tons of electronic devices in service that will die due to this problem.
If you are adventurous, you might pull the plug on the set, gain access to the innards, and with good light, inspect any boards inside.
You are looking for components that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many (not all) will show signs of pregnancy when they fail, bulging unnaturally when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will be four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
If you can't find any components that are visibly swollen, the supply may be cycling because of a power component, probably in the horizontal output that has shorted and it may have been dealt the death blow by a failed flyback or horizontal output transformer. This will be the largest single component you will see and will have a heavy lead coming from it that is attached to the CRT (picture tube.
To sort this out, you really need some technical skill and a minimum of a digital multimeter.
Posted on Sep 18, 2008
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Turn on tv no picture no sound standby light starts green changes to flashing red
the number of red light flashes indicate where the fault lies...sony error codes are easy enough to find if you google the model with the number of flashes.hope this helps somewhat as you dont say how many blinks!!
regards,steve.
ps.line output transformer failure rates are quite high on these sets,usually resulting in two red blinks-pause-two red blinks-pause etc...
Sep 28, 2010 | Sony FD Trinitron WEGA KV-28CS70 28" TV
Sony grand wega turns off & o ever 30sec flashes green light
it's a power failure.try to replace the regulator in power supply board.
Sep 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
1999 sony trinitron color tv -no picture-no sound.
Hello c_car,
What is happening is that the Shutdown Circuit is turning the TV off due to excessive current flow. The excessive current flow is most likely the result of a problem in the HV (High Voltage) section of your TV. This could mean that the Horizontal Output Transistor or the Integrated High Voltage Transformer has malfunctioned (developed a short circuit). I would advise that you let a qualified TV technician work on the set due to the nature of this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 19, 2009 | Televison & Video
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
