Question about Sony 2GB Memory Stick PRO Duo Memory Card
Can't read from the sony mem card.
I have a 2gb high speed memory card that I've been using for a little over a year with my phone. Recently I noticed I can't take anymore pictures with my phone camera because they were getting corrupted, so I took the mem card out of the phone and put it in my sony laptop that has a memry card reader. I was able to access all the files, so I copied them over to my pc and then put the stick back in the phone and that fixed the issue. However, when I tried to put my music back into the card using the laptop, I noticed the phone doesn't recognize it anymore. Now when I even put the stick in the laptop, it just gives me a pop up saying that I should format it, but the format fails. I've tried FAT, FAT32, and NTFS using quick and normal format. Is there anyway to fix this? and anyone knows if sony has any kind of warranty for these guys or what??
  • greenbug248 Oct 08, 2008
    You have to put music in the exact folder that is automatically created by your phone. The same thing for video or image and other type of files (if any). For instance, if you deleted all in your laptop you can't just copy image files on card and then put it in your phone. You should make atleast one photo with a phone,allowing it to create image folder (with that picture) and then put inside that folder other pics from your laptop..
  • ast854 Oct 09, 2008
    right now I can't even use the card to create folders or anything. I cant access it with my phone or my laptop.
    Genius:
  • 1,234 Answers
Hello Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    If your phone supports upto 2GB memory card but you've got a 4GB. What'll happen to the phone if you use 4GB on it ? Will 4GB card cause any damage to nokia 3110c that supports maximum 2GB ?
    Thanks for visiting FixYa!
    If your phone only supports up to 2GB memory cards, then it will not recognize a 4GB memory card. You won't be able to use any memory card above 2GB at all.
    Sep 10, 2011 | Cell Phones
    My moto v3i not format 2gb scandisk micro mem card..that mem card also work with pc.in phone format failed msg wil display.
    was you format your memory using your pc??if the phone can not format usually i format my memory using PC with card reader to detect the memory to pc,i format my memory with FAT file system
    try it
    i hope this helpful
    thank you for using fixya
    Feb 06, 2011 | Motorola Mobility RAZR V3i Cellular Phone
    Cant read card
    check all folders on the mem stick. it may not be stored in the default folder dcm101. try in cpu that has memstick slot. playstation 3 are very easy to access sony files. Hope this helps.
    Jun 02, 2009 | Sony Cameras
    Phone won't read sandisk memory
    I have seen this happen a lot of times with memory cards and formatting is the only solution for this and in the formatting options choose FAT32 as it seems more reliable than FAT. I have last formatted(FAT32) my card two years back when I had problems like these and I haven't had this problem since then.
    May 04, 2009 | PNY 4GB microSD High Capacity Mobile Media...
    Inserting a 2gb micro sd mem card in lg webslider to have xtr spa
    You have to move each song/file to your external memory straight away after recieving it via bluetooth because it goes straight onto your phone memory. Seach your phone memory and move all photos, videos, music etc to ext.memory by selecting the file-select options in lefthand corner- move to external memory. If your phone cannot find your external memory then you havent formatted your memory card. Go to Settings-Memory Status(way way down the bottom of list)-External Memory-Format(lefthand corner). Just remember to move each file to ext. mem. straight away.Its a pain but you have to do it manually, the phone doesnt do it for you.
    Apr 21, 2009 | PNY 2GB microSD Memory Card
    Memory m2 card 8gb
    hi
    the solution 2 ur problem is that ur fone supports memory only upto 2gb.
    so i think nothing can be done else exchane ur card for a 2gb card.
    i hope ur problem has been rectified
    all the best
    Mar 10, 2009 | Sony Ericsson w580i Cellular Phone
    Memory card
    u ll hav to get track of the setting in ur cell about the memory card.. if any changes n the settings of mem card may display lik tis..
    Nov 26, 2008 | Nokia N73 Cellular Phone
    64mb to 2 G memory stick dou
    The 2 GB memory stick should work in your P990 and not cause any noticeable slowdown.
    May 01, 2008 | Sony Ericsson P990i Cellular Phone
    Memory Card
    check if your e2 can handle a 2gb mem card, most unit made three years ago cant handle even a 1gb mem card. check your unit capability first before buying a new mem card . [:0)
    Jan 04, 2008 | Electronics - Others
    Sony 2GB Memory Stick PRO Duo Memory Card Logo
    90 people viewed this question
    Top Sony Electronics - Others Experts
    Sandy Moore
    Sandy Moore
     Grubhead
    Grubhead
    Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
