Question about Kicker CompVR 05CVR84 Car Subwoofer
Kicker compVR 12
Hey I have 2 Comp Vr 12 in a box with a kicker sx 500.2 amp pushing them, the problem is when I turn the bass up and the volume on the head unit is all the way down there is a bad noise that comes from the subs, kinda like a hum or something. All of the equipment is new. Any help would be great. Thanks
  • 3 Answers
If you have your power wire and rca's running down the sam side of the vehicle than change them that is your problem interferance
Posted on Dec 18, 2008
  • 185 Answers
Get a ground loop isolator. and another set of rca's or just run the power wire on the other side of the car let me no if that helps please rate if help full or not
Posted on Oct 31, 2008
I have a comp s 12 2ohm kicker and a comp vr 12 dual 2ohm kicker how do i wire these to stay at 2ohms to the amp
you can wire them to be at 2ohm load you need two of the same speaker. its is very bad on the amp to run like that and you will not get a good bass sound because one will over power the other sound wise
Mar 23, 2013 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Hey names Nathan and I just got a kicker ZX300.1 and a I connected it to my kicker comp 12 and an alpine cde 102. So the problem is that the protection light flashes with the beat of the bass at high...
Your speaker wires could be shorting to ground at the subs or at the amp. You could be experiencing a drop in voltage when the bass hits. Check your power connection at the battery, fuse and amp. Check your ground connection at the chassis connection and at the amp.
Aug 19, 2012 | Car Audio & Video
I have a 2011 gmc sierra and im putting a kicker comp vr 12 in there and i was wondering how much airspace i would need the box im looking @ is .98 i hope its enough airspace and its ported box
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch sub the box size will be 13 inches x 13 inches x 13 inches. Hope this helps
Dec 04, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
What is a good price for two kicker comp vr dual voice coils?? How many watt does each one have??
2 10" Kicker Comp VR's will run you about $150.00 each new from most dealers a good price for 1 10" should be anywhere from $130 - 160 no more and never less.
$160 -$190 for 1 12 " CompVr
Jun 17, 2010 | Kicker Comp VR Car Subwoofer
Subs hit without volume on
1. Check Grounding system (Player and Power Amp).
2. Ensure your RCA cable is OK
3. You might adjust volume or bass volume on power amp to maximum, just set all to 50% while you are tuning.
4. Check the speaker out cables might contact the ground/ chassis
Mar 28, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
I have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
My car subwoofers work, but theres no bass
turn them off and carefully push in on the cone (gently) and listen for scratching or scraping- push strait in and they should flow freely in and out if they DO without feeling or hearing scraping the subs are probably ok, next its either the amp is not powerful enough or the box is not soundly built, by that i mean its too small for the subs- is the box ported or sealed? if ported try plugging off the vent temporarily and see if bass increases if it does i would permanently seal the box
Mar 13, 2009 | Kicker 06CVX122 12" COMPVX Subwoofer,...
Box size
http://kicker.com/Product_Manuals/93/104 , look at the tech manual, it will give you dimensions of sealed or vented and it will give you a couple of box ideas.
Feb 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Kicker CompVR 05CVR84 Car Subwoofer Logo
180 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
