Question about Hitachi Televison & Video
Hitachi 37LD8500 occasionally wont turn on, well! comes on then switches itself off into stanby mode and then continually does this on and off.IT 3 HOURS to come on the first time but since has only done this a couple of times but generally comes on within about 30 secs.Anyone advise on this!!!
SOURCE: Samsung DLP 62 inch turns off by itself after being switched on
I had the same issue but instead of shorting out the sensor, I removed the bulb assembly, cleaned the interior of the assembly and TV the best that I could with a vaccum and small paint brush. Once cleaned, I reinstalled the bulb assembly and the TV has worked for the last eight months with no problem.
Posted on Jun 27, 2009
  • 22 Answers
SOURCE: TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Posted on Nov 13, 2007
  • 320 Answers
SOURCE: sony kdf50E2010 Rear projection model Tv
3 flashes indicates that the lamp is not seated properly or that the lamp door is not closed properly. Try removing and plugging tne lamp back in, tightening down the holding screws and reclosing and tightening the lamp cover. This should take care of your problem, Please be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
  • 8617 Answers
SOURCE: 52"rca hdtv lights blink will not turn on
Thats the classic sign of the CP150, CP120 and CP114 capacitors having failed. By trying to power it up over and over the caps will eventually charge and the set will function untill you power it down. You can get the CP150, CP120 and the CP114 repair kit at and the kit contains the CD with repair instructions.
Posted on Dec 17, 2009
Testimonial: "thank you very much very helpful will order these parts& try it"
  • 8457 Answers
SOURCE: Stanby light blinks four times stops then four
Ur power supply board is dead.Tries websites, to buy a refurbish power supply board for the replacement.
Posted on Apr 12, 2010
My hitachi tv turned itself off, and now wont turn back on. The light flashes continuously in red. Approx 4-5 flashes every 10 seconds
My samsung did something similar, it was a problem with the motherboard. If you're still on warranty, get it repaired.
Feb 11, 2015 | Hitachi Televison & Video
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
From my experience with sony tv it's normal.The set is going through update mode.Leave the set for about 10 minutes and it should be back to normal.
Jan 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My nokia 6500 slide handset is start and nokia is coming after that phone is switch off. So please give a solution.
power off the phone and try to long press this keys * - 3 - Call key - then switch on..dont realese the key until your phone was turned on and go to stanby mode.
Jun 14, 2010 | Nokia 6500 Slide Cellular Phone
it seems to be the power management
right clik on desktop click properties
click on screen saver tab
and from there click on power
ther you can adjust monitor stanby mode
Jul 24, 2009 | Computers & Internet
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Wont come out of stanby mode ??
The trouble your describing tells me that theres a short in the output circuit of this unit. Unless you know how to troubleshoot solid state electronics, Please take to a pro to have it serviced , as there are no user serviceable parts inside this unit. Good Luck
Jul 24, 2006 | Panasonic SA-XR50S 6.1 Channels Receiver
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
