When printing all but a couple of lines print well.The lines that don't, have a line running through the text which hasn't printed
    Guru:
  • 558 Answers
Please check the alignment of the printer,
GO to Start --> Click --> Printer and Faxes --> Open the Printer available --> Click on the Printer -- > select --> properties -- > Print a test page,
Does it print correct?
If not, then reinstall the Catridge after shake them well.
Let me know if no goods
Regards
ELLIN
Posted on Sep 18, 2008
  • Puneet Jain
    Puneet Jain Oct 17, 2008
    Check out the setting if not kept on Fast Draft (make it to best print or Normal)
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me
    know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
JmmyPge697
  • 39 Answers
SOURCE: Photosmart c6180 printer is printing
You should first try uninstalling and reinstalling the drivers for the printer. If this doesn't correct the problem, try replacing the cables to the printer.
Posted on May 10, 2008
SOURCE: 4580 all in one less than 6 mos old started printing half lines
try to clean the print heads of the ink cartridges. you can do it in the HP solution center. you can run it through all 3 tests so you make sure its clean. if it doesnt work after that, your ink cartidge level might be off, because i hear they never work half the time anyways. i would buy new ink if the cleaning the heads does not work. good luck!
Posted on May 23, 2009
hsanfor
  • 71 Answers
SOURCE: changed black ink cartridge to LD brand. Now
Canon printers do not like non Canon inks. Maybe other printers have similar issues but it seems that Canon is particularly finnicky.
Posted on Jun 20, 2009
  • 10406 Answers
SOURCE: white lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
Posted on May 29, 2010
SOURCE: Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
Posted on Sep 20, 2010
CANON IP 4300 PRINTERS WILL ONLY PRINT ALTERNATE LINES
I think your text document didn't fit the page. I have done that before. It overruns and the extra becomes the lines inbetween. To fix this use microsoft publisher to print it so that you can choose the paper size and the borders and fit the document within the space allowed.
Nov 24, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
White lines running through printed line
May 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Prints photocopies fine but pages of text have lines missing
Run a nozzle check to see if all inks printing out correctly.
Apr 11, 2010 | Epson Stylus DX6050 All-In-One InkJet...
When it prints there is a line through the text printed that does not print and i need to know why it started printing like that all of a sudden. So it will print a line of text but there is a part of the...
Sounds like the print head is at fault. The print head is actually a vertical line of small wires that move in and out to form the dots as the head moves across the page printing one row of characters at a time. One of the wires has failed. While it is possible that cleaning the print head with contact cleaner will resolve the problem, it might be time to replace the print head, or likely buy a used working replacement printer at less money than the cost to repair.
Jan 18, 2010 | OKI MICROLINE 321 Turbo Matrix Printer
Looks like a braille text
Open the HP Printer Toolkit (this software was installed from the CD-ROM that came with the HP printer) and run a "cleaning cycle",
because some of the ink-jets are clogged, which results in the "all-white" horizontal lines, where some part of that line should be black.
Jan 05, 2010 | HP Photosmart 7450 InkJet Printer
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
Nov 09, 2017 | HP Photosmart 2710 All-In-One InkJet...
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Word text document not printing clearly on every line.
What version of Word do you have? What OS are you using?
Can you append a print to file to this thread so that I can see what data the printer is being sent?
May 09, 2009 | HP DeskJet 722c InkJet Printer
May 08, 2008 | HP PSC 1610v All-in-One Printer
144 people viewed this question
jasbo
jasbo
