Question about Harman Kardon AVR 130 Receiver
HK AVR130 Standby Button not working
Just wondering if anyone has encountered the standby button not working. The main power button turns the lights on, but since the standby button doesn't work it won't let the audio play. Very Strange. Any suggestion on fixes?
Posted on Dec 07, 2012
I am experiencing a simular problem; amber light stays on ; no other lighting appears. this occured after leaving the avr in standby mode for a long time. I even tried to reset the unit as stated in the last page of manual after the trouble shooting advice - still no response - good luck!
Posted on Dec 01, 2009
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
Why does my tecknika 40-920 lcd tv no longer turn on? The standby light is on but when i press the power on button/change channel button the stand by light changes to on, but the returns to standby mo
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 13, 2014 | Televison & Video
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
HK 3370 turned into protection mode after pluging in a playing iphone. Happened more than one hour ago but hk3370's power light is still red. How do I get this thing out of the protection mode?
turn unit off using main power button, hold down t-mon and cd buttons at same time as switching main switch on should power up and show reset on the display for a short time then dhould go to standby this has reset unit and should now be ok
Jan 10, 2011 | Harman Kardon HK 3370 Receiver
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
Yellow light on wii
It's just the way the wii works. Hold the power button for about 5 seconds and the power button will go red and turn off instead of going yellow and going into standby mode.
May 07, 2010 | Nintendo Wii Console
Not loading up to main screen
ok go to youtube and type" PS3 REPAIR/FIX" basicly what you do is put the ps3 on standby (the red light on) and then turn the main power off (the back switch) then hold the I/O button in the front (the on switch you use to put on standby) just hold it until it will go to standby then hold the I/O button again (the standby button) and then keep holding it until you hear one beep, then wait for two quick beeps. Then there should be a menu and select "Restore Defualt Settings". If it dosent work CONTACT SONY!
Mar 08, 2009 | Sony Playstation 3 (PS3) Console
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Durabrand LEDVD0701 dvd player
Taken from another site in case you still need to unlock it.
The Pacific hack works for this one!
Multi-Region Hacks for Pacific DVD-1001
To change the current region setting on this player
1. Press the Standby button on your remote control to place the unit into Standby
2. Press the Standby button on your remote control to turn on the unit
3. Press the Open/Close button on your remote control to open the drive tray
4. Press the Clear button on your remote control
5. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 6 button on your remote control
8. Press the 9 button on your remote control
9. Press the 0 button on your remote control
10. Press the Open/Close button on your remote control to close the drive tray
11. Press the Standby button on your remote control to place the unit into Standby
12. Press the Standby button on your remote control to turn on the unit
Oct 20, 2007 | Televison & Video
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Harman Kardon AVR 130 Receiver Logo
834 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
