Question about AEG Dishwashers
Aeg dishwasher favorit 665 i
I can't get water to come into my dishwasher in my new apartment, but it makes noises like it is working. Please help!
  • aegsucks Sep 18, 2008
    Thanks, but I don't know what all those things are. For example, how do I turn on the tap? I have fiddled with a bunch of things under the sink. There is a metal knob that I tried turning- is that it? And do I need to turn on the water in my sink, then somehow divert it to the dishwasher? I have never had an opportunity to develop my plumbing vocabulary, as I have always had appliances that magically use water without excessive coaxing or the need for a trade school degree. Can anyone explain these terms?
  • 126 Answers
TWO THINGS YOU NEED TO CHECK.IS THE PIPE FROM THE TAP TO THE MACHINE NOT JAMMED.ALSO YOU NEED TO CHECK THE FILTER THAT IS LOCATED WHERE THE PIPE FROM THE TAP SCREWS ON IF ITS NOT BLOCKED AND IS THE VALVE IT SELF IS NOT FAULTY.GOODLUCK.MOHAMED
Posted on Sep 18, 2008
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 19, 2008
    THE BEST THING FOR YOU TO CAN DO IS GET TO THE BACK OF THE MACHINE.YOU WILL NOTICE THREE THINGS 1.THE ELECTRICAL CORD 2.THE PIPE THAT DRAINS THE WATER OUT THE MACHINE 3 THE PIPE THAT LETS WATER IN TO THE MACHINE THAT PIPE WILL BE DIFFERENT TO THE DRAIN PIPE AS IT WILL HAVE A PART THAT HAS THREADS ON IT THAT WILL SCREW ONTO THE TAP AND ONTO THE MACHINE.THAT IS THE PIPE THAT MIGHT BE CAUSING THE MACHINE NOT TO TAKE IN WATER.IF YOU STILL HAVING A PROBLEM AND YOU LIVE IN A FLAT OR DUPLEX THAT HAS A CARETAKER ITS BEST YOU ASK HIM FOR SOME ASSISTANCE.IF NOT GET THE HANDYMAN IN YOUR AREA TO HAVE A LOOK AT IT FOR YOU AS ITS A BIT OF A HASSLE IF YOU NOT FAMILIAR WITH THE MACHINE AND ITS COMPONENTS.GOODLUCK.MOHAMED.LET ME NO IF YOU REQUIRE MORE ASSISTANCE
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
I have water in the bottom of my AEG OKO-Favorit
did you take the air gap by the faucet apart they plug alot the fist thing i usually check disconnect drain hose lay it in a pan does water drain, may need new pump
Dec 27, 2009 | Dishwashers
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
Sep 19, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
Dishwashers Logo
285 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
