Question about Maytag MDG9606 Dryer
Maytag dryer model LDE8410acw
My dryer is working, however is takes approx. 1 1/2 to 2 cycles to get the clothes dry. I have checked and cleaned all vents. Also my wife says this began after she tried drying my daughters shoes. Any correlation?
Have you checked the vent outside your house?  Mine was completely clogged with lint, and as soon as i cleaned it out the dyer was woring fine again.
Posted on Oct 05, 2008
  • 750 Answers
Hi james,
How old is the dryer?
Sounds like a bad element!
Age determines if it's worth the investment !
Posted on Sep 19, 2008
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
My Maytag Bravo dryer adds extra minutes to cycles. If I set it for normal or bulky it will run for some time and when I check to see if it's done it still has over an hour left on it, more than the...
Your dryer has a moisture sensor, if it senses that the clothes aren't dry enough it will extend the cycle. A couple easy things to check:
1. Be sure the spin cycle on your washing machine is working properly. If the clothes are too wet when you add them to the dryer your dryer will need to add more time to get the clothes dry
2. Be sure your lint filter is cleaned after each load, and have your dryer exhaust vent cleaned- it could be clogged.
Oct 29, 2013 | Maytag Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
My Neptue dryer wont dry unless I run it more than one cycle. model no. mdg5500awq. all lights work and seems to run fine it just wont dry the cloths unless I run it at least twice and jeans are three or...
Turn dryer on and go outside to the vent and check for a good amount of air coming out. If you do not have a good amount of air coming out, take the exhaust tubes apart and clean.
Jun 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
My dryer takes long time to dry the clothes. It
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
NOTE***(This unit is equipped with a dryness control board. if all points above check out ok, replace this board).
Jul 21, 2009 | GE Profile Harmony DPGT750EC Electric...
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
176 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
