Question about Acer Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
  • 408 Answers
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
SOURCE:
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
Replaced the power board on acer aspire battery will charge to 28% overnight but charge nlight doesnt lightup
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 22, 2012 | Acer Aspire 4720 Notebook
Battery won't stay charged
Bring the power cord/charger to a pc shop and have them test it. It might need to be replaced. Otherwise you need to replace the battery.
Jul 21, 2012 | Acer Aspire 55155879 Laptop Charger...
Aspire 1 laptop won't turn on but the light bulb
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Acer Computers & Internet
Acer aspire 4339-2618 will not turn on
Is the new charge really one that is supposed to work with your machine? If so leave it plugged in for a about 3 hours and let it charge the battery. Then try turning it on again with the power cord and battery in place. If it still blinks and powers off remove the power cord and try turning it on with just the battery. If it blinks and turns off again the same way then you more than likely have a motherboard issue. Lets rule out the static charge issue by removing the power cord and the battery, then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in but leave the battery out and try to start the system up again. If it boots then put the battery back in and Thank The Lord because a dishonest repair shop would have charged you for a motherboard repair. If you can't get it started get a quote from your local computer shop then try the guys at http://www.generalsystemsconsulting.com They will fix it and ship it back by Fedex or UPS. Most times their price beats any quote you find including the shipping charge.
Mar 14, 2012 | Acer Aspire AS43392618 PC Notebook
I have acer aspire 4741z, when I plug the battery charger, it says plugged in, not charging (6% available). how can I fix this problem? thanks a lot
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Acer Aspire 4730-4947 Notebook
Acer Aspire One D255E battery meter says 100% charged but computer shuts down when you unplug power cord
That's often the sign of a worn-out or defective battery. They appear to charge but don't store enough energy to work. It's also possible the motherboard's power circuit isn't working. The only way to know for sure is to have a known good battery as a test, or to try your battery in another computer. If your computer works with a good test battery, or your battery causes another computer to shut down, you know you need a new battery. If the trouble continues with a good test battery, you'll need to have the computer serviced.
Jul 03, 2011 | Acer Aspire One D255E13438 Netbook
I'm using a "ACER aspire
There should not be a problem provided the notebook is used with the battery on occasions and charged up again when the battery level drops to approx. 25% level.
Jun 15, 2011 | Acer Aspire 5742Z-4200 Notebook
Computers & Internet Logo
732 people viewed this question
Ekse
Alun Cox
