ILO dtv2784 codes for direct remote
Same
3 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: Trying to program my DIrect TV remote to work my ILO TV
SEARCHING FOR YOUR CODE IN AV1 OR AV2
MODE
If you were unable to find the code for your brand of TV or
component, then you can try a code search. This process may
take up to 30 minutes.
1. Turn on the TV or component.
2. Move the slide switch to the AV1, AV2 or TV position.
3. Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch position
flashes twice and then release both keys.
4. Enter in 9-9-1 followed by one of the following 4-digits:
COMPONENT TYPE COMPONENT ID #
Satellite 0
TV 1
VCR/DVD/PVR 2
STEREO 3
6. Point the remote at the TV or component and press
CHAN ��. Repeatedly press the CHAN �� until the TV or
component turns off.
Note: Every time CHAN �� is pressed the remote advances to the
next code and power is transmitted to the component
7. When the TV or component turns off, stop pressing the
CHAN �� key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component
responds, then you've cycled through all codes and unfortunately
the code you need is not available. You must use the remote that
came with your TV or component.
Here is the link to your manual:
http://www.directtv-advisor.com/support-files/direct-tv-remote-manual.pdf
Posted on Dec 12, 2007
i have two tvs 1 is an Ilo and the other is a Sylvania. the code for sylvania works for both tvs on the Direct Tv Remote Hope this all helps and here is the code. 10171, there are also two other codes for this tv and they are 10054, and 10030. Have a good day and happy watching.
Darklove_420
Posted on Jan 31, 2009
gopakumarg43
  • 69795 Answers
SOURCE: I can't pair my direct tv remote to my ilo 42" tv
Codes to check are 0027,0028,0019,0082,0078,0022,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Posted on Mar 12, 2013
Have RCA Universal remote model RCR504BR need codes to program digital stream converter box and TV ILO NO.DTV2784
This remote control have no set-up code to digital stream. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 26, 2015 | RCA Televison & Video
REPLACEMENT TV REMOTE
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Mar 29, 2014 | Redi-Remote ILO Replacement Remote Control...
Rca universal remote (#rcu600ds) no code for ilo tv
I called the number on the Ilo TV. 1-800-289-0980. They suggested trying the codes for either ILO, Orion or Sansui. I got the Orion Code 0135 to work with my new GE remote.
Feb 06, 2010 | RCA Universal Remote Control
I HAVE A PHILIPS UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM IT TO A ILO TV. AND ALL I KNOW IS BY THE BATTERIES IT HAS CL019.
It is highly unlikely that if you had the code book that there would be an Ilo code. You have three options:
Option one is to purchase a high end universal remote that has an auto search feature for the correct code, since Ilo is unlikely to be one of the offered codes. Ilo does not build their own tvs, but vends out manufacturing of the sub assemblies and puts their name on it.
Option two is to go online directly to Ilo and purchase the original remote. Be prepared for sticker shock. Original remotes can be expensive.
Option three is use an external tuning system to your tv such as a cable box or vcr which will allow you to change channels remotely using the remote that controls the device. Many cable company boxes have remotes that also control the volume and on/off functions.
Apr 28, 2009 | Philips Magnavox Learning Universal Remote
Need codes for Sanyo RMT-U340 for RCA TV and Toshiba VCR
You may download the codes at http://www.sanyotv.com/RMT-U340A%20(ES)%200192--.pdf
Now if you could possibly get the codes to operate the Ilo or Cyberhome DVD DVR I would be most greatful.
Mar 22, 2009 | Directed 434MHZ Remote Control
Darklove_420
Nov 10, 2007 | One For All URC-3021 Remote Control
Innovage Jumbo universal remote
For the ILO TV Emerson Code 198 Works for the Jumbo Universal Remote. I bought one for my mother and had the same problem
Oct 26, 2007 | Televison & Video
Direct tv codes
THE CODE IS 11610 AND IT WORKS!!!! :)
Sep 22, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Electro Med Services...
