ADMINISTRATOR PRIVILEGES I AM USING A 4GB VERBATIM PEN DRIVE... I M LOGGING ONTO MY COMPUTER AS THE ADMIN.... BUT WHEN I TRY TO FORMAT THE DRIVE OR WHEN I TRY TO DELETE ANY INFORMATION, IT ASKS ME TO LOG IN AS AN ADMINISTRATOR... WHEN I TRY TO FORMAT IT UNDER DISK MANAGEMENT, IT SAYS I DONT HAVE SUFFICIENT PRIVILEGES AND M SUPPOSSED TO LOGIN AS AN ADMIN OF THE COMP... ANY SOLUTIONS????????
  • 781 Answers
This may seem long way round but download " Hirens Boot CD " burn to disk and boot from it it has a lot of useful programs on it including removing password setup so you can start afresh when windows reboots with no password
Or try booting in safe mode and format from there if possible
Posted on Sep 19, 2008
Transfer failed because you do not have access privileges
your transfer did fail because you do not have access privileges! i mean what can i say about that. get the privileges to that site and then maybe you can transfer your files. good luck.
Nov 02, 2017 | Computers & Internet
How do i start the game (race driver 3) but it states [please login with administrator privileges and try again] but i don't know what to do "?"
Do you have admin rights on the computer you're using? If you do, it shouldn't be a problem.
If you don't and you have Windows, right click on the icon for the game, and you'll see the option to run as admin.
If this still doesn't work, you'll have to talk to whoever has admin right to the computer and ask them to open it for you, or give you rights on that game so you can play. You're not logging into the game, your being asked if you have enough rights on that computer to do it.
Aug 08, 2016 | Codemasters TOCA Race Driver 3 for Windows
HI I HAVE TRANSCEND 4GB PEN DRIVE...I M TRYING TO OPEN MY PEN DRIVE OR TRYING TO FORMATTING BUT MY PEN DRIVE CONNECT 10SEC AND DISCONNECT....EVERY COMPUTER AND ANY LAPTOP I USE BUT SAME PROBLEM IS RUNNING...
Plug in the drive.
  • Right click on Computer, Properties
  • Select Manage
  • Select Disk Management
  • After the drive "disappears" if it is no longer visible in disk managment, I'd say it is a bad drive. If it shows as offline, try deleting any partitions on it and formatting it in disk managment.
Dec 18, 2012 | Electronics - Others
How do i format my usb drive
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Dec 31, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
One I have to insert my pen drive in friend lab tab that Os is Vista that time pen drive ask formate ur drive I gave formate command on that time of my pen drive is not working Locked my pen drive is...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Oct 29, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Cannot Read Store 'n Go Privacy Zone
It sounds like there needs to be an additional account created for the patron on the library computers. This account would have the same name as what was used to set up the Store 'n Go, or it could also be something like "Guest" if there are more than one user. She probably is using an admin account on her home computer so she doesn't have problems. Use the library admin account to grant access to the Store 'n Go for the new account.
Apr 03, 2017 | Verbatim Store `n' Go (94933) 2.1 GB Hard...
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
I forgot my password to my dell xps m1530 laptop and cant log into my computer how can i bypass this and change it
METHOD 1:
One of the easiest solutions is to enter through another Administrator account, there is a bunch of hidden accounts with administrative privileges that come pre created in Windows for troubleshooting, the most common ones are named “Administrator, Owner, XP“. Any administrator account can reset the password of any other account.
If you’re NOT using the Windows XP log-in screen (the one with the icons for each user), you can try logging in with the account named ‘Administrator’, which is hidden on the XP log-in screen. If you are using the XP log-in screen, try pressing Ctrl + Alt + Del to reach the old, NT-style screen, which should allow you to type in the user name.
METHOD 2:
If no other account with administrative privileges exist (which is really rare), you will need to use a password cracker to crack it. Ophcrack would be my first choice as it is freeware and performs the job fast.You will have to use another computer to download the iso file from ophcrack.sourceforge.net, burn it onto a CD using any burning application (I suggest DeepBurner as it’s freeware).Boot from this CD and watch Ophcrack go to work. Based on extensive password tables, it can recover most passwords in a matter of minutes, for all the accounts on a PC.
May 04, 2009 | Computers & Internet
Verbatim Thumb Drive problem
You may need to log on to the computer with administrative privileges. Ask your friend to log you into the Administrators account, then insert the drive.
Sep 02, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
