Question about Auzentech Inc. HDA X-Plosion 7.1 DTS Connect Sound Card
AuzenTech AZT-XPCINE 7.1 Channels 24-bit 96KHz PCI Interface X-Plosion 7.
I have the card connected via optical cable to my reciever (HTPC) I switch my reciever to the channel designated for the Optical Outlet, yet I get no sound. The Spdif cable is not connected on the card because both of my drives are sata. I am thinking of going coaxial, but I fear I may have the same problem. Does the SPDIF not being connected cause my problem?
I can't find samplerate setting
Most advanced music software propose a menu to set the sample rate and resolution, so you can use your audio interface without setting the sample rate in the control panel.
If you want to set it anyway, in case you are in Windows (for example Windows 7), you can click on Windows button (Start button on older Windows), choose Control panel, go to Sound, and in Sound, you can select Inspire 1394 in the playback list, and click on properties.
In the Advanced tab, you get the default playback format, for example 24-bit 96KHz, and you can change it.
Jul 27, 2014 | PreSonus INSPIRE 1394 External Sound...
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
Just brought aamsung home theatre and cant get tv channels to play through it
the LG has optical audio out put. If the samsung has the same optical input,then use an optical toslink cable to connect and select that input. Other wise Gefen(co) makes optical to analog adaptors available on ebay. You may also be able to run the audio out of you sat reciever or cable box directly to the "aux" inputs of your samsung via reg rca stlye cables and select that input!
Jun 04, 2010 | LG 42LG50 42 in. LCD HDTV
How do I install a new CD drive in an old destop computer It is an old Compaq Presario 5WV254 The existing CD drive has a ribbon type connector that mates up to the pins on the drive plus a 4 pin module...
The Compaq Presario SWV254 Desktop PC uses IDE technology, not SATA.
In the specifications for the above Desktop PC, it states ATAPI is used for the interface technology, and connector, for the optical drive/s.
[IDE is also referred to as PATA. Parallel ATA
SATA is Serial ATA.
The PATA designation was implemented, so that computer users could easily distinct between IDE, and SATA technology]
1) The IDE interface cable, (Flat ribbon cable), has a connector on each end with 40 socket holes.
(39 are actually used. Most of the time, one socket hole is blocked off. (Pin 32)
2) The SATA interface cable has 7 contact pins. Also referred to as a Data cable.
3) The IDE devices, (Harddrive and optical drive), use a 4-pin Molex connector for the power cable.
4) The SATA devices use a 15-pin connector on the end of the power cable.
More info on SATA,
http://en.wikipedia.org/wiki/SATA
The Samsung SH223C optical drive is a SATA device.
You cannot just plug it in.
IF, you have an open, (Available), PCI slot on the motherboard, you can use a SATA adapter card.
The SATA adapter card plugs into the PCI slot, and has the necessary connections on the card, for a SATA interface cable.
(NOTE*
Just for the SATA interface cable. Does not have a connection for the SATA power cable, you need.
You have to buy a 4-pin Molex to SATA power cable adapter, and connect it to an available 4-pin Molex power cable, on your power supply.
You will also need a SATA data cable. The interface cable that goes from the SATA adapter card, to the SATA optical drive you're trying to install)
This is an example of a SATA adapter card. It is not an advertisement for said website, nor manufacturer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1281807&CatId=1455
Jan 06, 2010 | Compaq Computers & Internet
Reply...
Creative Sound Blaster X-Fi Surround 5.1 will be the best option as creative soundcard worls great with creative speakers....
Jul 27, 2009 | Creative Labs Inspire T6100 Computer...
No Sound , have no sound card
The Formosa VIA1721 24bit/ 96KHz 8 Channel PCI, is the sound card you have. I found a driver for the card.
Here is the Link to the website and driver.
I hope this helps,
Eric
Jan 18, 2009 | VIA Soundcards: Formosa VIA1721 24bit/...
Not getting dolby digital or dts
Not available on this unit...accordianman
Feb 06, 2008 | Chaintech AV-710 7.1 Channel PCI Sound...
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Auzentech Inc. HDA X-Plosion 7.1 DTS Connect Sound Card Logo
105 people viewed this question
Top Auzentech Inc. Computers & Internet Experts
David Payne
David Payne
Are you an Auzentech Inc. Computer and Internet Expert? Answer questions, earn points and help others
