Question about Sharp AL 1631 Copier
Low toner with full cartridge
I recently replaced the toner cartridge, but the red lights are flashing again and the copier will not make a copy.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Which red lights are flashing and is there an error code as well?
ES IMPORTANTE SABER QUE LUZ ESTA ENCENDIDA PARA PODER AYUDARTE
Posted on Sep 19, 2008
My Sharp AL1530CS Copier is sick. I have a Sharp AL1530CS Copier. It has been great but has gotten sick. I replaced the AL110TD cartridge recently with a generic cartridge and toner leaked from it
Your machine is jamming (flashing p) because the toner that spilled has made the rollers slippery and they cant pull the paper out of the paper tray.
Apr 07, 2017 | Sharp Office Equipment & Supplies
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Oct 09, 2009 | Samsung ML 2010 Laser Printer
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Toner low indication
Take out toner and shake up down . And put it again. may it will help you . Else let me know.
Feb 18, 2008 | Xerox Phaser 3124 Printer
Sharp AL 1631 Copier Logo
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
