I need a service mode code for TV "RCA" J20531BL, chassis CTC176I2! "Menu"(hold down"), Power, Vol+ not working!
  • 10,594 Answers
If you are asking how to enter service mode in tv...procedure is like that...
1. TV turned on
2. Press and hold the 'Menu' button at the tv.
3. Press and release the 'Power' button.
4. Press and release the 'Vol up' button.
5. Release the 'Menu' button.
6. The initial security parameter displayed will be 'zero' Change this to '76'.
You are now in the Adjustment mode
For more info, click THIS we blink.
Posted on Sep 18, 2008
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
on Apr 29, 2015 | Panasonic Televison & Video
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sanyo mode...
Hello
You just try one the procedure given below. One amoung will lead you to its service mode.
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Dec 16, 2010 | Televison & Video
RCA d52w26 Field service menu
RCA > HD52W66
itc222a chassis
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec.
http://home.austin.rr.com/doctorjoe/ITC222align.pdf
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
Service Menu RCA HD56W58 56" TV
http://www.hdtvoice.com/voice/showthread.php?t=24248
go to http://www.thomsonnetwork.com
Click on "publications ordering" (in the list on the lefthand side of the homepage)
Click the box for service information. Enter the model number (or click the chassis button and enter the chassis number).
In the list of documents you can purchase for $40 ESIATC32X -- the service manual on CD for your set.
This disk will have the info you need.
If you do decide to purchase it (and I highly reccommend you do so), send me the alignment chapter and I would be happy to post it for others who have the same set on my homepage.
Jan 28, 2008 | RCA HD56W58 56" TV
Service mode
To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift.
You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Dec 11, 2007 | RCA P46812BL 46" Rear Projection...
Can't get into service mode.
invest in a service call,you tried .
Nov 04, 2007 | RCA 32F531T 32" TV
Service menu
Have you tried replacing the EEPROM? It may have lost it's programming for that set. Stargazer
Apr 19, 2007 | Proscan PS36123 TV
Service menu
Turn television off and then hold ch - and vol - on the tv, not remote, for about 10 seconds and it will come back on with service menu up. There you can change alignment.
Apr 19, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
Electro Med Services...
