Question about Lexmark Office Equipment & Supplies
I need to reinstall my printer without an install disk. I did it once, and it failed to install the whole thing. My computer is saying that there is a problem communicating with the printer. Lexmark X4550. Windows Vista, Compaq.
    Sergeant:
  • 399 Answers
Just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
thanks.
Posted on Sep 18, 2008
WINDOWS 8 PREVIEW INSTALLED ON LENOVO IDEAPAD AND IS NOT WORKING PROPERLY SO TRYED TO RECOVER TO WINDOWS 7 BUT NOT WROKING!!!!
You will need a separate recovery disk. Sounds like the recovery partition of your HDD got overwritten. Maybe you can create a windows WinPE (microsoft docs) and use that. This says what to do once you have a recovery disk.
https://pureinfotech.com/how-to-uninstall-windows-8-developer-preview-and-restore-windows-7-step-by-step/
Sep 25, 2017 | Lenovo IdeaPad Computers & Internet
Need to install hp officejet 5610 all-in-one without disk
Download the software and drivers from HP and reinstall.
Jun 23, 2010 | HP Officejet 5610 All-In-One InkJet...
My Hp Deskjet F4200 series printer will not scan anything to my computer, but it will copy just fine. How can I get it to scan? I have already uninstalled the printer driver & reinstalled it. It says...
Check to see that your Scanner drivers have been installed. Click on Start, then Printers and Faxes and see if a Scanner is listed. If not, you need to install the drivers.
Also, when you uninstall the printer drivers, you first need to disconnect the printer from the computer, and unplug the printer from the power source. Leave the printer unplugged for at least 15 minutes to clear the printer's cache memory.
Next, go to Add/Remove Programs in your Control Panel and uninstall the printer software. Then, turn off your computer.
Next, reboot your computer. Place the Deskjet cd in the drive and follow instructions for reinstalling the printer software and drivers.
CAUTION: DO NOT PLUG IN YOUR PRINTER CABLE TO YOUR COMPUTER UNTIL PROMPTED BY THE INSTALL DISK!!
Oct 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Canon printer not functioning
Sir,
Restart your PC and Printer once and even it does not work then
your need to reinstall driver for that printer.
please post back if anything changes.
thank you,
Jan 10, 2009 | Office Equipment & Supplies
HP printer 1200 cannot access Hp director
I had to redo my whole computer because of virus. when i reinstalled windows xp my hewlett-pachard psc 1210 will print. I get a message that says it is not installed and I have tried everything to get it to work. no disk i even install a driver but still wont work help please
Oct 24, 2008 | HP Office Equipment & Supplies
XP says printer is seen as new hardware and won't go away
When you do a restore on those, yes, you load XP, then you have to run the drivers disk.
The trick is, after you restore windows, you have to install the chipset driver first.
Reboot
Then do sound, NIC (NIC has to be done manually), and video (don't worry about the USB drivers, they get taken care of in the windows updates)
Reboot
After all of that is in, do your windows updates (of course reboot again)
Then do windows update manually (START>Update Windows, Custom) and make sure to include hardware updates.
Once all of that is in, then attach the printer (don't turn it on) install the printer software, and turn the printer on when it tells you to.
Not doing the restore in this order will result in the errors you are getting.
The chipset drivers first is the key to the whole project.
(I've probably done 100+ of these).
I don't know if you can go back in now to do these steps, you might be better off, starting all over.
Try that, and let us know.
Sep 07, 2008 | Dell 922 All-In-One InkJet Printer
Ricoh ac204
You probably need the whole application to get it to work. Usually Ricohs use a memory resident program to control scanning functions. That way you can fax or scan to e-mail with them.
You can check on www.ricoh-usa.com to see if there is a Twain driver for that particular model.
Jun 09, 2008 | Ricoh AC204 All-In-One Laser Printer
Trying to instal photosmart C4380 all in one wirelessly on toshiba L40-17M from supplied disc installed printer ok first time but scanner not recognised, scan button says computer connected but computer...
Photosmart C4380: good hardware, appalling software. Shameful that it's on the market at all.
WIRELESS PROBLEM
You have to install the printer as USB first. Then, once it's all installed, load up the CD again and 'Add device', choosing the wireless option. It's crucial that you leave your USB cable in the whole time. Take it out right at the end. Once you've added a device, you'll have two printers installed. One will be called 'Copy 1' - that's the wireless one. It should all work okay, and you can delete the USB one.
SCAN PROBLEM AND ERROR MESSAGES
When I did this everything seemed to work fine. BUT - after a wee while the software started playing up. The scan function didn't work at all, HP was depositing all sorts of bugs all over my computer, I had error messages coming up at shutdown, all sorts of gremlins.
So this is what I did.
I totally uninstalled all HP software.
I downloaded the updated Photosmart Basic Drivers from the HP website. They are here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3221646&lc=en&cc=us&dlc=en&submit.y=11&submit.x=9&lang=en&cc=us
Once you've downloaded the file and run it, the new drivers will be installed but NO SOFTWARE. Again, you have to do the whole setting it up as USB and then leaving the cable in and adding the device wirelessly. But if you do this with the HP drivers and ignore the installation CD, then everything should work perfectly.
Of course this means no HP software at all. But who needs it? I use Microsoft's scanning software, which is fine, and it has no problem printing.
Basically HP's software is BLOATWARE that doesn't even work. It screws up your computer.
Good luck!!
Apr 21, 2008 | Office Equipment & Supplies
My printer was installed. now my computer says it not. the problem is that my install disk got destroyed. what do i do to reinstall it?
You need to download the appropriate drivers from the Lexmark website and install it in to your PC. Once their homepage has opened up, pls move your mouse over to the "Drivers & Downloads", click on "Driver Finder", Enter your printer model in the "Search for your Printer by Model Number" and click on "GO". Click on your Operating System. After successful download, click the file to install. Pls follow on screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 08, 2008 | Computers & Internet
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
