Question about HP Compaq Presario V2205US PC Notebook
Battery removal I cannot remove the battery. It seems simple but the latch will not move. Is it possible that whoever replaced it last time screwed it up? Should I force the latch?
    Sergeant:
  • 399 Answers
Yes it is possible .but do it gently it will move if you force and the latch gets damaged it will not hold the battery inside properly.
thanks.
Posted on Sep 18, 2008
Howtoremovedoorpanelon93blazer
Hi, to remove the latch there are two screws holding. First remove the screw on the inside of the door (near the lock mechanism, you may have to move the rubber seal that runs on the side a little to get to this screw). The second screw could either be from the inside (here the door panel covering will need to be removed) or from the latch itself ( here you will need to remove any covering with a thin screwdriver on the handle ) to access the second screw. sounds complicating but once done is very simple. Best of luck>
Jul 14, 2014 | 2006 Volkswagen New Beetle
Trying to reverse door swing on Samsung washer WF405ATPASU/AA
Tony, this is a simple procedure and you just need a medium sized phillips head screwdriver. Start by opening the door and removing the two phillips screws that attach the hinge to the machine. Remove the door by lifting up and out. Next, remove the two screws that that you will now see (previously hidden under the door hinge that you just removed). Now, go to the opposite side and remove the two screws that hold the door latch and pull out the plastic latch insert. Also, remove the two screws located (about 4 inches) above and below the latch insert. Now simply reverse the process by securing the plastic latch on the left side along with the two screws (top and bottom). Before securing the door on the right side, lay it down and remove the screw that is used to hang the door (within a slotted hole on the machine) and move it to the top of the hinge (you will see a hole for it). Now simply hang the door on the right side of the machine, and firmly secure it with the remaining two screws. Your door should move freely and latch securely.
Dec 16, 2013 | Samsung Washing Machines
Our battery is dead on our 2004 Toyota Sienna, now our key wont manually open the doors
You will have to open the hood to jump start or change battery. There are two ways to open the hood, both involve the hood latch/locking mechinism. First thing you must find a way to do, is to access the hood latch with your hands. You may have to get under the car, or maybe remove the grill to be able to get to it. Try to pull the hood release cable with your fingers or with some pliers. If this proves too hard to do, try to use a strong stick or rod and try to get the latch to release that way, moving the release the same way the cable pulls it. Another option is to access the screws that hold the latch on to the car, remove the bolts and lift hood, latch and all up. Then replace the latch/lock when you get your battery fixed. If you decide to lift hood, latch and all up by removing the bolts/screws, watch out and don't break your cable, just lift the hood enough to seperate the latch from the hood.
Dec 16, 2013 | Toyota Sienna Cars & Trucks
Battery compartment latch broken
battery latches broken, battery needs replacement, you will end up forcibly removing the battery thereby doing more damage to battery latches but avoid main computer case. cannot open computer to find solution around broken latches for there are screws that needs to be removed under battery.
Sep 06, 2013 | Dell Computers & Internet
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
Dishwasher won't reset...any thoughts
I have the same problem. I decided to try to fix it myself. I opened the door and took out all the screws from the interior outer edge. (8 screws in all) Be careful if you do this, because when you remove the last screw, the entire front panel will come off. Once the front panel is removed, you will see there is a folded up piece of paper, the service data sheet. That is good for reference.
Usually the clean light goes off when you open the door, but in my case, it stays on even i open and close the door many times. That led me to believe that the door latch switch may be defective. I checked the wiring going to the switch and it seemed fine. Then, with the door open, i used my fingers to push the latch back and forth a couple times. Bingo! The clean light went off. So, i presume that the problem is a faulty door switch. I turned off the circuit breaker to the dishwasher and pulled off the wires on the latch connectors. (Making sure i labeled where each one should go) Then i removed the 2 screws that hold the latch in place. Now i have the door latch/switch removed, and i can easily get a replacement and reinstall the new one myself... The part number on my latch/switch is 154556701A, 11600-85, 0704. These numbers are printed on the side of the switch. I will update on this problem once i have completed the repair.
Sep 20, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Broken door latch whirlpool ghw9100lw1
The following link explains how to replace the door latch on a Whirlpool front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is a very simple repair. I'm surprised at the cost of the labor you were quoted. An experienced technician can replace one of these latches in 30 minutes or less.
An alternate method of the replacing the latch is the remove the top panel of the washer and work down through the top. Due to variations in design features between models, this isn't always possible. If you want to remove the top panel, just locate and remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. If you have access the latch assembly from the top, you can attempt the repair using this method.
If you have any questions, please let me know. I hope this helps you.
Sep 02, 2009 | Whirlpool GHW9100L Front Load Washer
How to replace bios battery in A10 s129 toshiba sattelite laptop computer?
Hi bjcermd,
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was less that a 15 )
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the plasic clips.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws (less than a ton).
Thanks
Smith
Jul 15, 2009 | Computers & Internet
Won't charge even though Green light is on and connects to computer. Just put a new battery in.
Yes, possibly a cracked pc board if the unit was dropped. But check to make sure that the charging unit's connector is clean as well as the unit to be charged. I had a problem with my wireless phone and a PDA not charging because of dirty contacts. I got to the contacts using a long Q-tip moisten with Isopropyl alcohol and scrubbed them clean. I now do it about twice a year. No problems since then.
r_olivarez@juno.com
May 23, 2009 | Tomtom GO 910
HP Compaq Presario V2205US PC Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
