Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity Washer beeps & won't spin
Hi - My front-loading Frigidaire Affinity is beeping continually and won't spin the water out of the basket. It is only about two years old. I had just run a heavy load of blankets when this started happening. I tried unplugging it, and getting it to start again in a different cycle - such as "spin only", but it shuts itself off immediately. I can't get it to start again for more than a couple seconds, and then it just flashes and beeps. I see others have asked about similar issues with this washer, but I havne't found any solutions. Hoping someone knows out there...
Thanks!
  • 7 more comments
  • mrsmader Sep 19, 2008
    My washer is only a year old and it won't drain all the water out and it flashes E20. It won't spin, it just makes a noise like it's draining or trying to spin but nothing is happening. THIS MACHINE SUCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
  • kath B Sep 26, 2008
    I am having the same problem E20 please help
  • jennyrench Oct 06, 2008
    won't spin and get an error e2o
  • EmmaJane Oct 09, 2008
    I have a 6000 model and same problem It started where i couldn't do heavy loads- no more than 4 towels on a towel load and you know, i bought the darn thing because I was told it was great for larger loads and could handle up to 8 or 9 towels! But now, it won't spin. Runs until the spin cycle, beeps three times a time or two as if the complete cycle has run, and no error code ever displays. However, the clothes are still soaked. I've cleaned out the trash basket and checked hoses and the pump. Too many people seem to be having this same problem on all different websites- I think these machines have some manufacturing problem. Going to call a repair man tomorrow and if its too expensive, will get rid of this one and get something that WORKS! Haven't been able to do laundry in almost a week- never would have paid $1000 for a machine if i had known i would keep having issues with it. This is the second time this has happened.
  • disgusting Oct 25, 2008
    Water won't drain and the beeper keeps going off.  Nothing looks clogged.  Can't find the pump.  Where do you open this machine up?
  • kariegirl Dec 17, 2008
    So, I have the same washer and mine flashes E20 and i accidentally put a diaper in with a big load so I am assuming it is clogged. Where is the filter? I don't have a manual.
  • Anonymous May 01, 2009
    how do I get to the filter?
  • manaw May 11, 2010
  • Anonymous Mar 15, 2014
    My Frigidaire Affinity washer will not spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
Posted on Oct 19, 2008
  • Christine Fontaine Dec 12, 2011
    How do you get to the filter? Mine is doing the same thing and we don't have the money to get a repaiperson to look at it
Picked up a free Affinity 6000 & found unit would not spin. Found the door safety switch contact spacing that was supposed to close when the wax motor heated up was too wide and the travel of the wax motor plunger was inadequate. Adjusted the stationary contact closer to the contact that is moved by the wax motor to ensure this N.O. door safety switch contact now makes when the wax motor heats up. Cost for repair $0.00 !!!
The "wax motor" is a small white rectangular plastic device with 2 1/4" male wire terminals. It has printing on it with its 120vac current rating. Inside the door lock/safety switch this wax motor heats up when 120vac is applied by the washer controller during spin cycles. As this wax motor heats up it acts much like a automotive engine coolant thermostat and the expanding heated wax pushes out a plunger which engages the door lock mechanism & pushes together the previously mentioned switch contacts that signals the washer controller that it is safe to spin the washer drum at high speeds.
Posted on Mar 18, 2010
I had the same problem. Filter in the drain boot was full of coins($1.37), lint and a ring my daughter lost a year ago. The boot was a pain to get to. Once I got to it, getting the hose clamps off was much easier than putting them back on. I replaced one of the hose clamps with a ring clamp from the hardware store. Poor design. Coins and such shouldn't be able to transfer past the wash drum but they do and it causes a problem which you nearly need a professional just to clean a filter.
Posted on Jan 10, 2010
The filter inside the drain line was full.I chose to not put mine back in and just check our pockets alittle more carefully.
Posted on Oct 21, 2008
Stay away from using Purex 3 in 1 detergent/fabric softener/anti-static cloths.  Two worked their way into my drain line, causing the poor drainage and slow spin problem.
Posted on Jan 25, 2010
Another reason this happens is the door lock sensor. This happened to me- I cleaned out the trash basket, the drain boot- everything. The door was locked- but for some reason the computer wasn't recognizing that that door was locked so it would not go into the final spin cycle. Called a repairman who replaced the door lock and the machine is good as new. I can even do really heavy loads again. thank goodness!
Posted on Oct 20, 2008
I read your post about fixing your Frigidaire front loader. You stated you relocated the "wax motor" for the door lock. Could you please explain how and where to do this? My washer is giving an E10 code and will not do the final spin so that my clothes are completely soaked. Thanks in advance!
Posted on May 29, 2010
After you clean out the filter, check to see that nothing is stuck in the pump impeller as well. You may have to take the motor apart
Posted on Mar 02, 2010
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
When tub drains beeps twice and won't continue
Hi - Does the drain pump make a humming noise as well? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to I reset my Affinity to factory settings? I know you hold down to buttions for a few seconds but I forgot which buttons they were.
Hello, Thank You for using FixYa. I will be helping you today.
push the Spin Speed and Soil Selection keys simultaneously and hold
until you hear a beep. This is no more than 10 seconds
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity e 25
dip as much water out as possible remove bottom panel remove hoses from pump ckd hoses and pump for blockage
May 21, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
3,952 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
