Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Water not draining
Water will not drain out of the bottom of the dishwasher on a Tecnik 795 dish washer? After cleaning under the screen it still will not drain out.
  • Anonymous Oct 06, 2008
    Water just bdoesnt drain. Whatever is done!
I have the same problem, I understand that a little water won't be a problem, Question? about how many gallons of water are distributed throughout a cycle or cycles of wash.
Posted on Oct 19, 2008
  • 126 Answers
PLEASE REMEMBER THAT THE MACHINE DOES LEAVE A LITTLE AMOUNT OF WATER BEHIND.AS LONG AS THE WATER IS NOT ABOVE THE FILTER MEANING THE MESH AT THE BOTTOM THERE IS NOTHING WRONG WITH THE MACHINE.GOODLUCK.MOHAMED
Posted on Sep 18, 2008
2 Suggested Answers
SOURCE: Water not draining
were is the drain plug located and how do we remove? help
Posted on Sep 27, 2008
A lot of water stays at the bottom(in fact) of washed dishes(crockery) What do I have to make?
There is a drain screen on the bottom of the dishwasher that needs to be cleaned out on a regular basis, especially if you put in dishes that haven't been rinsed off. Food waste will plug up the screen and not let the water drain out fast enough
If that screen gets blocked, the water doesn't have enough time to be drained from the washer during the timer sequence and the water will remain at the bottom.
Mar 06, 2015 | Miele Incognito G858SCVi Built-in...
TECNIK TDK 795 FAULT
is there the power supply still to the washer??
Mar 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
When my dish washer discharge water instead of the water going out the drain it come out the overflow valve.
The dishwasher usually drains into disposal, or directly into tailpiece, and water drains down to the p-trap.
Trap may be clogged or stopped up.
Clean out drain line, tighten connection where dishwasher attaches.
Clean out bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 18, 2012 | Kohler K-692-7 Clairette Kitchen Sink...
HOW DO I DRAIN WATER FROM MY SMEG DISHWASHER
There is a screen filter at the bottom of most dish washers, if the screen gets dirty it probly won't drain properly. Check the screen and clean if neccesary. If not that, then pump may be getting weak.
Jun 25, 2012 | Smeg Dishwashers
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
The dishwasher did not drain. What is the best way to unclog the drain?
Remove water out of dish washer to acess the screen to clean it out in the bottom. Once it is clean you may have to remove the drain hose to clean it out.
You may be able to remove water with a shop vac or cup to get water out of washer to check it out.
Food will get in the bottom at screen or past it and lodge in right before going to pump to stop it up.
Aug 14, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Dishwasher not draining,took side off but cannot get to pipes to clear them, please help!!
Have you cleaned out the screen in the bottom of the dish washer. Sometime's food will get in the drain there past screen to stop the drain up. That would be the first place to check.You could use a shop vac to get up excess water to get to drain to clean out inside unit.
If this doesn't help I have included a little information on how to remove dishwasher from cabinet to acess drain line.
If you can't acess the drain line you may have to take dish washer loose and slide out to get to it. To do this remove 2 screws that are connected from tabs's near the top of the door under the cbainet top.
Open door and look up and there should be two metal tabs with screws in them holding the washer in place. Next you will need to shut water off and disconnect the water line which will be located near the left front at bottom once you take the removable panel loose.
Also shut power off to washer and you may have to disconnect the power supply if it isn't enough wire to pull unit out. If you if has enough wire and water line you maybe able to get it out without disconecting them.
On the back side of the pump the drain line is connected to it. You may be able to take it loose from underneath, not much room if it can be taken loose with unit in place .
Anyway I hope that I have included something that maybe of some help to you.
Aug 13, 2010 | Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Water not draining
Jan 25, 2008 | Frigidaire 25 in. FDP750RC Free-standing...
Tecnik integrated dishwasher 795/2
make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Aug 27, 2007 | Frigidaire 25 in. FDP750RC Free-standing...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
314 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
