Question about Sharp AR-5320 Black and White Copier
Sharp AR-275 Getting H2-00 Erron on power on
Getting the following error on power on : H2-00
  • mmm12345 May 21, 2009
    hi; i am from Germany, have a problem wit my sharp ar 275. i have clened . then i had error code h200. i had saw thas meaning ,H2-00, Fusing unit temperature error,
    how can i taht code reset? or have u idee how can i repair? or must i everyone unit change? (sorry for my englisch:))
    pls help i need taht
    thank u
    Problem Solver:
  • 5 Answers
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Posted on May 27, 2009
  • n1a1s1a1 Feb 21, 2011
    working fine now
    Problem Solver:
  • 10 Answers
This is a fuser code, most common couse lamp burnt out or thermal fuse is blown.you'll need a volt meter to test the fuse and lamp,
Posted on Sep 19, 2008
New canon t2i. keep getting error 70. haven't even been able to take a single picture
hello. good day. error 70 is appears when malfunctions related to images have been detected.
try doing the following:
1. power down camera and remove battery
2. power down HDMI device or powered adapter
3. unplug the HDMI from the body, then plug it back in
4. power up HDMI device or powered adapter
5. insert battery and power up camera
hope this helps. is error still appear. try this link for canon support http://www.usa.canon.com/cusa/about_canon?pageKeyCode=50
Apr 29, 2011 | Canon EOS 550D Rebel T2i Digital Camera
With power button push in the light comes on and fan comes on but in 5 seconds it turns off. I've tried with battery out and just with power plug , still the same results.
Can be one of the following
  • Remove battery and power lead - press and hold the power ket for 60 seconds. put in power lead and it may start.
  • If you are getting beeps or lights flashing then you have a Power On Start up Test (POST) error. This means you have a hardware failure in the system. The actual error depends on the motherboard and the error beeps. Solutions vary depending on the error, can be from replace memory to motherboard is shot. Please let me know if you are getting beep codes, this may need professional repair.
  • Does not start and no beep codes, then the power or the motherboard has failed, this will need professional repair.
Jan 19, 2011 | Toshiba Satellite M65-S809 Notebook
We keep getting error codes when using our machne
hi,
u didn't mensionend the error code number any where. error code number is must for find out the problem. any way do the following and inform me is it worked or no.
p { margin-bottom: 0.21cm; }
Power the Spot Vital Signs off, wait five seconds, and power on. If the error code
reappears then power the Spot Vital Signs off and disconnect the battery for five minutes.
Reconnect the battery and power on. Press the Blood Pressure Start/Stop button to reset flashing patient alarm conditions.
0k
Dec 29, 2010 | Welch Allyn Spot Vital Signs Monitor with...
Hi My Sharp AR-275 has problem of U2-40 now. I tried Solution 1 or removing toner cartridge and replacing the same one (because there is still 50% left). And also I tried Solution 2 or press #...
The U2-40 error is the machine telling you that there is a communications error with your CRUM chip.
is there anything at all displayed on the screen??
if there is, press the #, interrupt, C, interrupt in rapid succession. If you don't know what the interrupt button looks like, it is the third button from the right on the control panel. You may have to try it a few times, as with age, the buttons are harder to push so they register that you are pushing them. Once you get into the simulation mode, press 16, then start, and follow the on-screen instructions. once the machine has reset the code, usually shows by going back to the main code screen, then press the CA button, or "clear all".(second button from the right) that will reboot the machine and hopefully clear the code.
Nov 03, 2010 | Sharp AR-275 Copier
What does code u2-40 mean and how do i by pass it
Hello, You can download the manual here http://sharp.diplofix.com/forum-SHARP/AR-275
It looks like this error is a CRUM chip error, which could be caused by the type of toner cartridge you are using, and or the actual CRUM chip. The connector could be bad (check the connector for the toner cartridge) or when you replaced the toner cartridge; it may have bent the plate that it is mounted on and it needs to be straightened, realigned.
Oct 07, 2010 | Sharp AR-275 Copier
Error code L6-10 on sharp ar-275
try to reset or replace the polygon motor
Nov 17, 2009 | Sharp AR-275 Copier
I am getting the following error code "00989C98" L7780
Hi this appears to be part of a generic problem possibly caused due to power surges…
As recommended by HP on these types of errors:
1: Disconnect the USB cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB cable, and try to print a print job from the computer.
If this works, please grade the answer... If the steps don’t work I would recommend you check with HP.
(the steps highlighted above are from the support website from HP)
http://h10025.www1.hp.com/ewfr...product=2512009&dlc=en
Cheers,
Ed
Nov 07, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Sharp AR-5320 Black and White Copier Logo
729 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
