Vertical output I saw your response to a ? someone had about this problem and was wondering if this Vertical Output was an LC or ic?You stated it was either defective or needed to be resoldered.I am having this same problem.And,is this something I can fix myself or should I bring it to a repair man? Thanx 4 helping, Ken
  • Ken Sep 21, 2008
    Sorry to bother you again but you have gotten me closer to fixing this set than anyone else ive chatted with.I was wondering if you could tell me where it is located and what it looks like.Ive searched the net for 2 hrs and cant find anything to help show me where to go now.I have a friend that said they would solder it for me if thats what it is! Thanx again,
    Ken
  • Ken Sep 22, 2008
    Hi,Model # is Mitsubishi CS-3503R
  • 8,617 Answers
The vertical output is a ic . If youre handy at soldering you may be able to repair it yourself. If youre not comfortable soldering close solder connections, it may be best to have a professional do the repair.
Posted on Sep 19, 2008
  • Sonny Berry
    Sonny Berry Sep 22, 2008
    vertical output ICs are usually 5 to 7 pin standup ICs that are attached to Heatsinks.Usually they have a TDAnumber stamped on them. If you can post the model number of your set I can help you better in locating it.
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Where is horizontal output ic in my t.v?
There is no horizontal oscillator IC. The horizontal oscillation is generated and outputted by the main system control IC LA76810 itself. Refer some circuit diagrams using LA76810 to get more details about the horizontal oscillation output from the IC. Measure the frequency at that output pin. It should be some ever near 15.62KHz.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the IC number, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 31, 2015 | Televison & Video
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
Tv has horizontal lines on top of screen.
Hello
You are seeing vertical retrace lines on the top of your TV screen.
There are mainly three causes for it. I don't know the age of your TV. The first cause is due to the supply voltage lack to the video output state. You can check it on the picture tube base card. You haven't mentioned about the diamension of your TV screen. So it can be say as a guess. If your TV is 27", the voltage mantioned above will come to about 245VDC. If there is a great voltage loss, check the smoothing capacitor to that supply, will normally come to the value of 10MFD 450V.
The second one is, capacitor related to the vertical output stage of your tv. It is in the circuit board. Normally these capacitors are situated in an area, which will get hot during working. As s result, there is a chance to the value change of their capacitance. It is best to replace all of them, as it may not cost too much. Before desoldering it out, mark the value of each capacitor is best. Normally replacing the filter capacitor 3300MFD or so,to the power supply to the vertical output Ic will solve this problem.
The third is related with the vertical output Ic itself. Just check all the soldering points in the vertical output section of your tv board. Anyway, resoder all suspected soderings by applying a little more solder, as bad solderings to the legs of the Ic or some other components also may the cause. OK.
Nov 10, 2010 | Toshiba Televison & Video
Circle Vertical IC please on picture
I've cropped out most of the picture so it would fit here. The vertical output IC is I601. It's circled in the picture below:
If you can't place it from this part of your image, it's on the heatsink just above and to the left of the horizontal output transformer, which has the high-voltage lead running to the picture tube. Resolder the IC connections and that will probably take care of your trouble.
Mar 08, 2010 | Hitachi 32UX59B 32" TV
Unit has sound, no vertical deflection. caps and output ic ok. have b+ to output. nothing at pin 2 of output ic.
If there's an audio,,it might be the defective Vertical IC...but check first if there's 24v-26vdc supply coming from FBT going to Vcc of Vertical IC.
If there's no Audio,and only white horizontal line in the screen,check the Vertical out of Jungle IC.
Oct 12, 2009 | Toshiba 27D46 27" TV
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Followup question on the advice to pass on the $100 tv.
no its a DLP they are having some troubles with the dlps losing signal due to the digital board. verticle ICs only effect CRT projections by making the CRTs shutdown . Dlps are all controlled by the digital board. They are very expensive when you can find them. They are usually over 800 and need to be special orderd. I would pass on the TV. You can buy one cheaper than fix that
Mar 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Jul 03, 2007 | Sharp 27K-S100 TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
