Question about Brother MFC-7220 All-In-One Laser Printer
Brother 7220 I cant send a fax it continues to tell me that the number that I am calling is busy but it goes busy before the number completely dials
    Scholar:
  • 147 Answers
You might need to dial 9, followed by a comma or pause, if you are faxing from inside an office.
You might need to dial 10 digits, if you live in a high density location in North America.
If you're dialing a long-distance number, the person paying for the line may have disabled long-distance calling - check with parents / spouse / boss / landlord, as applicable.
Posted on Sep 18, 2008
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
Jun 12, 2012 | Brother IntelliFAX 1840C Plain Paper...
I have a Brother fax machine. When I dial a number to send a fax, there is a noise on the speaker in addition to the fax dialing and it defaults into a busy signal. What should I do?
The number u are dialing is either busy or someting is wrong with the phone line thus not connecting to the other party. The fax set up may be confiqurated wronlgy.
Regards
Sep 28, 2010 | Brother Office Equipment & Supplies
WE CANNOT RECEIVE OR SEND FAXES, BUSY/NO SIGNAL
Plug a phone into the jack and check to make sure you have a dial tone. If not telephone company needs to be called. If dial tone it may be the other number you are trying to fax to. try calling the number from phone and see if it picks up.
Aug 25, 2010 | Brother Office Equipment & Supplies
Can't send faxes. I always get the answer thar
you have a dialing problem.
If you are sending your fax long distance, you have to dial a 1 before the area code.
Mar 21, 2010 | Brother MFC-7220 All-In-One Laser Printer
I have a MFC 7220...today it will not send a fax
You need an ANALOG phone line for faxing, not DIGITAL.
Mar 19, 2010 | Brother MFC-7220 Plain Paper Laser Fax
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
Cant receive fax
FIRST OFF. IF YOU PLUG A PHONE INTO THE JACK DO YOU GET DIAL TONE? IS THE WALL JACK PLUGGED IN TO THE RIGHT JACK ON THE MACHINE? NEXT GO IN TO THE MENUE SET UP FOR FAX. GO TO THE SECTION WHERE YOU WILL SEE EASY RECEIVE AND EASY SEND, ON BOTH OF THEASE PRESS SET OR OK THIS SHOULD NORMALLY DO THE TRICK, IF ALL FAILS, THEN YOU MAY NEED A PHONE BOARD CALLED A NCU BOARD. GOOD LUCK BROTHER SR TECH
Jan 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Fax sending prob
Unplug the power cord for 10 seconds.
Oct 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Brother MFC-7220 All-In-One Laser Printer Logo
108 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
