Question about Maytag M7DH45B2A Dehumidifier
Full light comes on early
My dehumidifier's "full light" comes on and shuts it down when the tank is less than a quarter full. I cleaned the filter really well and it worked well only twice before it started doing it again
    Scholar:
  • 147 Answers
Most dehumidifiers rely on a float sitting in the pail to rise, turning off the switch. Check and see if the float moves clean and smooth, and is sitting in the pail rather than resting on it's brim.
There may be other safety switches, like a temperature sensor to turn it off if it runs the risk of freezing up or overheating.
Posted on Sep 18, 2008
Does not shut off when tank full, water leaks all over the floor if I don't watch it constantly
Sounds like the float valve inside tank may be stuck in closed position. Calcium buildup is very common. Good luck Juliana. Unplug and empty tank of any water and look for the float valve it should be near top of tank. Use a small bucket and mix vinegar and water and brush. Scrub that valve. Clean it up
Jul 13, 2016 | Windchaser Dehumidifiers
Full light stays on always
Don't know your model specifically, but most dehumidifiers have a float that shuts the system down when the tank is full. Maybe the float is not going up and down like it should. With the power off and the tank out, see if the float is descending like it should when the tank is out. Popping it up and down a few times might solve the problem.
Apr 13, 2014 | Comfort-Aire Dehumidifiers
Red exclamation sign blinking
Dehumidifier? Sounds like a warning of some sort. A humidifier does a simple job, removing moisture from the air. If yours is not set up to drain, it could have a full holding tank. Empty it out and give it a rinse and it should be good. Drop a couple drops of chlorine bleach in it to keep down the mold growth.
If it isn't a full tank, it could be an air filter that needs cleaning or replacing. Often these things are programmed in and needs to be cleared. Clean and or replace any and all air filters and look for a reset button.
Good luck.
Mar 15, 2014 | Dehumidifiers
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    Where is the float
    Don't know your model specifically, but the float is usually at the top of your water tank and activates the system to shut down by popping up when the tank is full. With some tanks you can actually reach in and sort of clean off the float. Jelly-like stuff can build up on the float after a number of years. Cleaning it off wouldn't hurt.
    Sep 09, 2013 | Comfort-Aire BHD-651 Dehumidifier
    Unit will turn on for less than a minute and then shut itself completely off. It is not the switch for the bucket and the filter is clean. Any ideas on what can be causing the problem?
    More than likely. the humidity extraction level is set to high. Lower it to 32 - 35%. If the unit is being used in a basement application, to air temp at floor level may be to cold. Setting the unit up off the floor on to a sturdy table or cabinet top, that is sturdy enough to handle the weight of the unit, plus a full tank of water will help.
    Jul 04, 2011 | Maytag M7DH45B2A Dehumidifier
    My zenith zd309 light keeps blinking but the water
    If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
    Jun 07, 2010 | Dehumidifiers
    3 yr old Gold star / LG dehumidifier stopped working
    Here is a tip that I wrote to help people with just that dehumidifier problem..
    Dehumidifier Problem It shows Bucket Full
    http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
    heatman101
    Apr 30, 2010 | Dehumidifiers
    Not removing water and says tank it full
    I just had one giving me the somewhat the same problem. Upon taking it apart I found that the entire inside was filthy. This thing runs in a work area in my basement and sucks up all of the dirty air. When you take the water out of the dirty air you have nothing but the dirt and the water. When you mix those together you get mud which is what clogged everything up in mine.
    Dehumidifiers need to be clean on the inside to run properly especially all of the fins on the condensor. You will probably have to take it apart and clean it. Concentrate on the fins and the water collection areas. Dehumidifiers remove heat from the air which causes the humidity to collect on the condensor. As it collects it turns into water droplets. Gravity pulls the water droplets into the water collection areas and that flows to your tank. There is some sort of float in your tank that lets the dehumidifier know it is full and shuts it off with some sort of switch. It does this so it does not just keep running and eventually pour water onto your floor. It sounds like your switch and/or float is stuck. Find the float and switch and manually work them to make certain they are working freely, clean if necessary.
    If the dehumidifier does not remove water like it should it is probably not getting good airflow. There are ice sensors on the evaporator that tells the compressor to stop working. However the fan will still run to pull warm air across the ice so that it melts, goes into the water collection area and into your tank. Some of these ice sensors work by measuring air flow. If there is no air flow or very limited air flow the sensor will tell the compressor not to work. The fan will run again to melt the ice so that it melts and is removed. If your condensor is dirty and does not allow the air to flow, this could cause your problem.
    Mar 24, 2010 | Danby DDR6588EE Dehumidifier
    Maytag M7DH45B2A Dehumidifier Logo
    100 people viewed this question
    Top Maytag Dehumidifiers Experts
    Bill Long
    Sr. Pelo
    Sr. Pelo
    Steve
    Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
