Question about Refrigerators
Neff American Fridge Freezer leaking at bottom
We have acquired a Neff American Fridge Freezer when moving in to our new house. Every so often we get a big puddle of water under the fridge/freezer. I have tried to work out when this happens but there doesnt seem to be any particular time. Ive noticed that in the freezer there is a build up of ice on the bottom. I think that this is somewhat to blame for the puddles of water??? Im at a loss to be honest. Ive tried turing the temperature down and this seems to make a slight difference to the frequency of the puddles.
People keep telling me to unblock a tube???? I dont know where they mean. I cant find one.
Please help.....its driving me mad!
  • Skylinks Sep 20, 2008
    Normal
    0
    Leaking Problem. I have a Zanussi Freezone Fridge/Freezer. ZK
    56/38 RF ZEM GLY 80AA
    R134a. The fridge is at the top: the freezer is at the bottom. Every time the freezer door is opened some
    water leaks from the bottom of the door seal.
    There is a thin layer of ice on the bottom of the Freezer section. Inside the bottom food box there is a small
    amount of dust-like frosting. Otherwise the unit works perfectly. How can I stop it dribbling over the floor
    on opening the door?
SOURCE: American fridge freezer - sansumg rsh1dtmh
I had the same problem. There is a circuit board on the very top of the fridge/freezer. There is a 5amp quick blow fuse on there. Sounds like that has blown. Mine did for performing the same function. replaced it and all is good.
Posted on Feb 20, 2008
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
SOURCE: water leaking on floor from under Mod#TPH21PRS;TPH21PBS
Check rubber gasket around Freezer door it's probably hardened at bottom and probably not sealing properly allowing air (hot air from outside and heat from under refrigerator) to get in from beneath and causing condensation to build ice, than melt thusly occasional thawing and leakage. Gasket part number wr2yx525
Posted on Aug 13, 2009
Richie_asg1
  • 1036 Answers
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Posted on Sep 08, 2009
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
I have a WESTINGHOUSE WSE7000SF side by side
Yes, they can and there will be a wayer line on the freezer door side that will also need to be disconnscted at the bottom.
Sep 21, 2014 | Refrigerators
Hi i have a fridgemaster fridge freezer and it was moved from mil house on Wednesday. It now will not freeze although it does get some ice at the back of freezer but then defrosts itself. The fridge will...
Have you made sure that that the water connection to the ice-maker is secure and without leaks or stopped up (kinks) in some way? I would suggest that you unplug it for bout 30 min., then plug it back in. See what happens about after 45 minutes. If it was moved, you want to make sure you have tapped into the main water line. It doesn't just magically happen. Sometimes the simplest things can cause immedite problems.
Jan 18, 2018 | Siemens Bosch Neff Integrated Fridge...
There is constantly water on the bottom of one side of our fridge. I need to put a tea-towel in to soak it up and this needs replacing everyday. Fridge is still cold and combined freezer is working...
This can be due to overflow of the defrosted water from the collection tank. Also check if there is leak on the tank or the deforsted water pipe line from the evaporator.
You need to move the fridge forward to confirm on this, drain the water from tank and check.
Aug 08, 2011 | Neff Refrigerators
Roper fridge is leaking
the back wall of your freezer need to be open to make sure the drain hole is clear and you can clean it with turkey pump. good luck ez job :)
Dec 30, 2009 | Refrigerators
How do i switch off freezer part of neff american fridge freezer?
turn off the thermostat on the freezer and the refrigerator and that should shut it all down.
Apr 03, 2009 | Refrigerators
Neff american fridge freezer, ice dispenser
Are your ice cubes to big or in the dispenser door not opening all the way both can be fixed adjust the flow timer on the ice maker or replace the door dispenser
Jul 27, 2008 | Neff K3965XO Side by Side Refrigerator
Jul 23, 2008 | Refrigerators
Refrigerators Logo
589 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
