Question about NorStar Meridian M7310 Phone
Caller id only displays after i pick up the line
Running a 3x8 nortel system with M7208 and T7208 phones. Caller id only displays after i pick up the line. Is there a fix for this?
  • redcross09 Mar 09, 2009
    I have the same problem! My co-workers do not have the same problem, I think it's just my phone.
  • Anonymous Mar 17, 2009
    how to install m8 caller id on 8x24 norstar dr5.1
It is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Posted on Sep 21, 2008
Is there a way to setup caller id on a Nortel system that show when the phone rings
In system programming, you can select whether the display is the name, number, or line.
enter extension #
skip Line Access, Capabilities, Name, User Preferences
Telco Features
skip Feature Assign
at 1StDisplay use CHANGE softkey to toggle to NAME.
Mar 26, 2014 | Nortel Lands Phones
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
On our 3 line Nortel T7208 it is showing 2 of the lines are in use, they are not, how do we clear these?
Reboot phone system or pull the jumpers off and re punch down to KSU.
Lines need to be programmed a Supervision Disconnect = YES both on phone system and the carrier, call a tech in to do this/check and also put in a repair ticket with the carrier to do same.
Supervision Disconnect monitors the lines to when you hang up it knows to release the line. Muck like back in the day you could hangup on that crank caller, pick up the phone a aminute later and he was still there.
Aug 07, 2012 | NorStar M7208 Corded Phone
Caller ID does not display name on Nortel phone
Cell phones do not send caller name, so create a Speed Dial entry for that number with the name you want to see. When a call arrives from that number, the system will show the name you have programmed.
Jul 11, 2017 | Nortel T7316E 2-Line Corded Phone
M7208 call display not working hot sure how to program it. when calls come in it does not show who is calling
So is the display not working or are you trying to set up caller ID?
M7208 phones were delivered with the very first Nortel systems and if you have one of those, you're not getting CID. The CICS cabinet or higher requries a CID trunk card and IIRC 5.0 or higher software. If all of those are in place, as a minimum you can press FEATURE 811 to display CID info.
Feb 05, 2011 | Nortel Meridian M7208 Corded Phone
Our caller ID has stopped working and this has nothing to do with our monthly ATnT service
The caller ID facility is an optional facility provided by your Operator and this needs to be activated from operator side in order to show in customer's Called ID device.
Please check it with any other line that has the same facility activated.
Jan 21, 2010 | Nortel Business Series Terminal T7208 -...
How do you set up caller ID on a Norstar M7208 phone with 4 lines?
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
Jul 23, 2009 | NorStar M7208 Corded Phone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Oct 25, 2007 | Lands Phones
NorStar Meridian M7310 Phone Logo
655 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
