Question about Technics Audio Players & Recorders
Hi i have a technics system but the cd player keeps jumping it seems like there is a scratch on the disc but they are new ! any ideas cheers leerobertsis@googlemail.com.
  • leerobertsis Sep 18, 2008
    hi,
    thanks i have tried that one already, but it still happens !
    could it be a problem with the stability of the disc ??
  • 10,594 Answers
Seems optical lens is dirty or have thin layer of dust on it.
open top cover of cd player and clean optical lens with good quality cotton swab with care and play again.
hope problem will resolve.
Posted on Sep 18, 2008
Technics SC-CA 1080 CD player jumps ,can I just buy any CD player separate and connect it to my technics? It's a separates 'style' system, not sure if its compatible with a different CD player
You have tried cleaning the lens? That might cure the jumps. Make certain your CD's are not scratched and clean too.
A separate CD player will work with your system, I think. It looks like the current CD player will connect via two phono plugs to the back of the system. Since the new CD player will have the same type, just remove the old connections and the power lead and plug the new CD player in the same phono sockets. As the new separate CD player will have it's own power supply it will not need the old one.
No further adjustments are needed. Any brand of CD player can be purchased.
Jan 21, 2016 | Technics Audio Players & Recorders
Hello, I have a Technics HiFi system - I've had it for 10 years. The problem is that the CD player skips and jumps. I've tried cleaning the CDs but there are no scratches on them. I've also...
Its time to replace the optical unit ( lens ) of the CD player. Brace yourself the unit on some of those old players can cost more than a new DVD player.
Jun 02, 2011 | Audio Players & Recorders
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
Hello please my cd player is jumping, when you play an audio cd it start skiping
If it only does it on some CD's see my Tip on removing scratches.
If it does it all CD's you need to clean the lens of the laser. If that doesn't work you might have to think about replacing the laser/lens. It might not be cheap either!
Dec 22, 2009 | Technics SCEH790 CD Shelf System
Cd player keeps jumping when playing cd
Try a CD/DVD cleaner disc. Try playing another CD after cleaning it. Do Not Wet the cleaning disc This will nock the lens out of focus
Jul 28, 2009 | Technics Audio Players & Recorders
Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
Dec 31, 2007 | Technics SL-PG480A CD Player
CDs keep jumping
The problem is not with the CDs, but with the laser pick up unit of your player. Cleaning the pick up unit is simple but I advise you not to venture that unless you are sure how to do it without damaging it, most probably this will fix the problem, if not you will have to change the pick up unit. If you are a techie, try adjusting the trimpot found on the pick up unit just a bit before changing the pick up unit.
Dec 18, 2007 | Technics SC-EH780 CD Shelf System
Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
Dec 08, 2007 | Technics SL-MC700 110-Disc CD Changer
Car cd player jumps
You can try a commercial laser disc player cleaner or have it professionaly serivced a repair store
Dec 07, 2007 | Clarion DB538RMP CD Player
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
