Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore frost free refrigerator
The frost free freezer keeps freezing up. At first the drain whole would freeze over, now the coils are freezing up. Is it not going into defrost mode?
  • wmadix Oct 25, 2008
    top freezer frost on back pannel and behind frost on evaporator Kenmore 2005 model # 10675249400
The back wall of my side by side is frosting over. the freezer side.
Posted on Jan 23, 2009
  • 943 Answers
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Posted on Oct 03, 2008
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
Freezer freezing up in the bottom vents, the fridge is not cold enough. the freezer works great. there is no drainage in the drain pan in the bottom. it is a frost free refrigerator.
The heater for the frost-free isn't functioning. Have a technician check the circuitry on the heater for breaks, or even a defective heater!
Feb 12, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Top coil is freezing up, the remaing coils are not getting cold.
low on freon or plugged to the point of where the frost stops on the evaporator. Evaporator should fully frost up on all coils...
Sep 12, 2009 | Kenmore 64802 Top Freezer Refrigerator
The freezer section of my Kenmore refrigerator isn't freezing
Defrost cycle is not working correctly. Bad defrost timer, heater or limit thermostat.
Sep 11, 2009 | Kenmore Refrigerators
Freeze will not freeze.
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 71192100 frost free keeps freezing up
Hi. thanks for the question . The first thing i would do is clear the drain tube .that could be why the freezer ices up .too much moisture Clean the drain, And the coils at the back. thanks the appliance doc
Sep 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
262 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
