Question about VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100 MATX Form Factor1xAGP (4X) / 2xPCI / 1xCNR / 2xDDR / 2xDI... (2277200350) Motherboard
What is the maximum athlon processor that is compatible with ecs k7vmm rev 1.2a
    President:
  • 2,351 Answers
Hi tenecniv18, click on this link from ECS it shows the CPU's supported for the ECS K7VMM 1.2A
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=67&MenuID=69&LanID=0
Main web site for ECS K7VMM V1.2A; http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=67&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
You'll need to flash the bios to version 20812 in order to run AMD Athlon XP 2400+ and 2600+ CPU.
See here; http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=67&DetailName=Bios&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
Enjoy!
Mike
Posted on Sep 18, 2008
    Master:
  • 441 Answers
Compatible processor in K7VMM ecs motherboard
According to the ecs website :
the K7VMM version 1.2A has a cpu socket 462 for AMD Athlon XP/ Athlon / Duron processor
Go to : http://www.ecs.com.tw/ECSWebSite/Index.aspx?MenuID=0&LanID=0
and use the ECS search box with your model # K7VMM
then choose your version #, click it
then click on the CPU tab (under the pic of the motherboard). It shows a complete list of compatible cpu's for this motherboard. Did this answer your question?
Dec 25, 2012 | EliteGroup K7VMM Motherboard
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
Swapped in 2 ddr 512 266mhz sticks for, 2 sdram 512 133mhz sticks. no boot, only beeps, neither sticks will work in either slots. cpu has a athlon xp 2000 133mhz processor, is this the problem? Do I need a...
Your motherboard works only with 100 or 133 MHz memory modules.
You hear the beeps because the motherboard is telling you that the memory is not compatible with the board.
The processor is not the problem.
Don't forget to rate this answer if it helps
Dec 05, 2009 | EliteGroup K7VMM Motherboard
Where could i donwload a sound driver for K7vmm soundcard
You can download the required drivers from ECS K7VMM download page by clicking this link
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Oct 20, 2009 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Looking for a compatible processor for this mobo
It is impossible to fry a motherboard by using the wrong processor, the board simply won't post. You can use a chart at the ECS website, your motherboard is a Socket A type. Looks like the fastest processor that they have tested is a Athlon XP 3000+.
Apr 04, 2009 | EliteGroup 741GX-M Motherboard
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100 MATX Form Factor1xAGP (4X) / 2xPCI / 1xCNR / 2xDDR / 2xDI... (2277200350) Motherboard Logo
1,301 people viewed this question
Top VIA Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
