Question about Frigidaire Dryers
We have a Frigidaire Gallery dryer with a moisture sensor. I've had this model in the past with no concerns, but our current model doesn't seem to work as well. When set to an "automatic" cycle (where the moisture sensor is used) the clothes don't always come out dry and it has to be turned on again. Would there be any reason for this?
  • dbowman77 Jan 13, 2009
    We have the same problem. The buzzer goes off and we ignore it the first few times. Is there any way to recalibrate the sensor?
  • 750 Answers
Mamch,
You said,We have a Frigidaire Gallery dryer with a moisture sensor. I've had this model in the past with no concerns, but our current model doesn't seem to work as well. When set to an "automatic" cycle (where the moisture sensor is used) the clothes don't always come out dry and it has to be turned on again. Would there be any reason for this?
What's the model # and the age?
There are two types of moisture sensors.
One has to strips of metal on a black disk looking thing on the dryer rear wall and the other works on steam rather than contact!
Could be you had the better on before that was the contact one rather than the steamm sensor!
How long to dry a load of clothes ?
Posted on Sep 19, 2008
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
How to clean debris below lint filter Frigidaire Gallery GLER341as1
Pull the exhuast vent off the back of the dryer, remove the lint screen and then turn it on for a few, should just blow out the back.
Jan 09, 2013 | Dryers
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
Where do I locate the moisture sensor bars on my frigidaire gallery dryer
Below the filter housing inside concealed from the ***** eye because: The wire to is connects to the front panel.
Aug 28, 2011 | Frigidaire Dryers
The timer on my dryer isn't working properly
HI. the timer motor is damaged at this point. The Auto sector is dead. This is not a serviceable part, and you will need to replace the entire timer mechanism to correct this issue.
Oct 02, 2009 | Frigidaire Dryers
Frigidaire Gallery dryer SMELLED like Burning rubber.
Reach inside and try to turn the drum. If it seems hard to turn then your glide kit (Part#5303937139) may be in need of replacement:
Apr 10, 2009 | Dryers
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
334 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
