Question about Samsung SCX-4100 All-In-One Laser Printer
JAM 1 or NO CARTRIDGE
Hello. My problem is that we checked everything, papar or cartridge, and everything is ok, but it still don't want to start. When we want to start it begins heating up, and it stops writing this message: JAM 1 or NO CARTRIDGE.
Can someone tell us what could be the problem?
  • Anonymous Nov 02, 2008
    I have the same problem. i had an electronics repair dude look it up and down and he couldn't find anything wrong but it still says "Jam 1 or No Cartridge". Funny thing is, it'll still print for a few seconds then stop, if I open and close the door it will continue and stop and if I do it one more time, the whole page will come out as usual, fully printed, but it will attempt to print the same page again because it registers the one just printed as a failure... What is causing this problem??? I just filled the cartridge with toner so it can't be no toner.
  • 31 Answers
Hi my name is joel garcia and i resolve this problem removing the toner and open the toner only removed 7 screw and move the tint with somthing and rode the film then close the tonner and put-on and problem gone if your film its broken need a buy new tonner god look!!!! sorry for my bad english
Posted on Jan 20, 2009
What is first print ok & secound print jam ?
check exist sensor and actuator.registration sensor and actuator.
Nov 01, 2014 | Office Equipment & Supplies
Piece of garbage jammed again, removed the jammed paper and am still getting error that it has a jam in cartridge area. I have taken out the cart. and blown it out with air and also took the back off and...
Hello denelson994,
Welcome, and thank you for using FixYa!
Your issue has to do with the paper sensor flags just under where the cartridge is inserted.
If there is paper or dust in that sensor(s), the printer will interpret that as a paper jam. Grab some canned air, blow everything out, and then physically examine those sensors under the cartridge area.
If the sensors were dirty, they should work now. If the "Flag" (plastic lever) that is pushed down as paper passes over it, is broken off; the sensor(s) will have to be replaced.
Make sure you flip up or back, any metal plates you can, to look for paper shreds or dust under them as well.
Have a great day!
Sep 12, 2011 | Dell 1815dn All-In-One Laser Printer
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back...
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
Jul 19, 2017 | Canon Office Equipment & Supplies
In the display show Jam 1 or no cartridge whats wrongs with this printer
hello
try to reinstall toner cartridge.check machine inside.sometime their have piece of paper
Aug 26, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Unable to initilise and checked the ptinter, which is al ok
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Jan 23, 2010 | Brother DCP 115C All-In-One InkJet Printer
Had paper jam. Followed instructions to release
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | HP Photosmart C6280 Printer
Papar jam
Hello sir; Wherever you clean up the paper jam, right over there have a paper senser ,check that senser is moving freely or out of track, just put it back to right possition.
Sep 25, 2009 | Sharp Office Equipment & Supplies
Phantom Paper Jam
There may be a problem with the fuser unit. First check all the doors and drawers for paper jams, including removing the toner cartridge and looking inside. Leave the cartridge out, turn off your machine, unplug for 1 minute, then turn back on. Close door without the cartridge inside. Machine should tell you to insert cartridge. Put it back in, and see what it does. If a simple reset like i have described does not solve the problem, there may be a small piece of torn paper somewhere, or a sensor may be broken or dirty. Please reply with the results!
May 07, 2009 | IBM Infoprint 32 Laser Printer
Paper jam 2 - checked every area - cut equipment off and back on - still paper jam 2 - need service person asap.
there are 4 or 5 sensors through paper road:
1)paper input sensor near input roller
2)margin sensor between input roller and cartridge unit
3)transfer bell sensor between cartridge and fuser unit
4)fusing sensor before fusing
5)out put tray sensor
check all sensors if you can find out and check any paper jam there and check sensor stander at normal position, also check each sensor click ok(the micro switch ok) .
there is any sensor out of work should be showing paper jam.
Jan 23, 2009 | Dell 1600n All-In-One Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
327 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
