Question about Wacom (EP130EPE) Digital Pen
Intuous pen "sticking"
Hi, I have been using my Intuous pen and Wacom tablet together for a few years with no problems. Now all of a sudden in the last week, it as if it is "sticking" to anything I select (and not letting go). I have no more control over this pen, and it won't select what I want or "click" when I want. I have changed the nib to the straight nib again (no spring), and have gone into the controls to make it less sensitive overall, but I am still having terrible problems. I use this pen for everything (not just drawing), and it's turning out to be dangerously "sticky"- selecting and moving (and deleting) things if I even get close to them! Help! I don't know what to do anymore!
  • 2 more comments
  • twoowurds Dec 12, 2008
    its quite the problem! its very frustrating. its like it just wont let go of files? it even starts selecting files and moving them around before I touch the tablet.  anyone have any info?
  • torgeir_berg Feb 22, 2009
    Instead of reacting as it should, it keeps making selections and it is way to sensitive now. The pen reacts even 1-2 cm before touching the plate. Anyone have a clue to fix it?
  • margoburns Apr 25, 2009
    Graphire4 pen doing the same thing. I have reprogrammed the 1st button to be a single-click, and can work around it, but it's really annoying. It's like the sensor thinks it's touched the tablet all the time...
  • Anonymous May 21, 2009
    mine selects but can't finish (e.g it won't select if i click or tap); it moves the cursor around, but i can't do anything with it.
  • 4 Answers
Take out the "nib" and whack it on your desk (or drop it on the floor from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this doesn't work, then the sensor may be too damaged.
Posted on Jan 19, 2010
  • sraible Nov 08, 2010
    Midnight. Started a new job at home after working at the studios for ten hours. Cotton Pickin’ pen started stickin’. Followed the above instructions. Works like a charm. Thank You. Off to work.
  • P.J. Ryan
    P.J. Ryan May 17, 2011
    I've had this "sticky" Wacom Intuos3 pen problem too. Just out of the blue. I use the pen for everything (relieved my "tennis elbow"). I, too, tried all the instructions in the manual - didn't help.
    I read somewhere else that there may be a spec of dust in the channel with the nib (I work next to the ocean, so there is indeed a lot of airborne particles, so this makes sense to me). So I have removed the nib, and blew into it to try and dislodge anything in there. The problem was reduced, but the pen still seemed sluggish.
    So, I just found your suggestion about the sensor. I removed the nib and whacked the side of the pen on the edge of my desk at three points along the length, then replaced the nib. It seems to be working. I'm optimistic that the problem is fixed. Thanks for your posting.
Turn Tip Feel all the way to maximum Firm
Posted on Oct 08, 2009
  • chad825
    chad825 Nov 01, 2012
    totally worked! thank you!
Why won't my wacom grip pen click when it touches the tablet instead of hovering and selecting text?
Have you tried pulling the nib out (the end bit you draw with)? It could be that something is sticking the nib further inside the pen than it should, which is telling the pen you are applying pressure. As far as I know there is a little spring inside the pen that the nib pushes on when you touch the pen to the tablet. Perhaps the spring is permanently squished in.
May 26, 2014 | Wacom Intuos3 Grip Pen
My Wacom Tablet won't recognize the pen.
you have to install the pen on the CD you have from the box you got it in
Apr 21, 2010 | Wacom Intuos3 Graphic Tablet
Wacom intuos3 pen is not working
A few hours ago Wacom released a new driver 6.1.2-5 for the Windows 7/Vista/XP operating systems. I was having the same problem. Hopefully this will be a permanent fix!
http://www.wacom.com/downloads/driver-detail.php?id=200
Nov 19, 2009 | Wacom Intuos3 Graphic Tablet
Wacom pen does not function
Unfortunately I had the same problem.
Its from moisture in the pen, could be from humidity or something spilling on it. Try searching google for information on how to fix wet electronics. (Im quite sure youre not supposed to use heat)
Sep 16, 2009 | Wacom (EP130EPE) Digital Pen
Wacom Intuous 2 stylus continues action after lifting
metho is good at cleaning electronics. it has to be high 95 %
Jun 01, 2009 | Wacom Stylus Pen for Graphire4
Pen Tip Not Working
I had the same problem and called Wacom Customer Care at 360-896-9833... I was informed that the pen was defective/ broken and needs to be replaced. This can be caused by being dropped and such. I was told that i should keep the pen on the stand or a eyeglasses case when not in use.
If your tablet is under a year old, warranty will cover the cost of the pen with proof of purchase. Other than that, you will need to purchase a new pen (about $29.99 from Wacom & online).
Unfortunate, but great to know.
Jul 16, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Initial Delay of tablet pen
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
Feb 02, 2008 | Wacom Intuos3 Graphic Tablet
Wacom tablet stopped working, blue light on.
Hey I had this problem too with my Bamboo too, I'm not sure if it was anything I changed or whatever but either way the blue light was on but it wasn't registering the pen.
I found a way just minutes ago to fix it however!
Go into 'start', 'all programs', then look for 'pen tablet'. Hopefully you should have this. If not then download the latest driver for your tablet from the wacom website and that should install it.
Next choose 'pen tablet preference file utilty'. Then under 'my preferences' choose to remove. Bingo! All was well in the world again.
This worked for me so hopefully it will for some of you guys too! Good luck!
Jan 15, 2008 | Wacom (PTZ930AC) Graphic Tablet
Loosing pressure sensitivity
I was trying also, didn't work at all, and I'm going to try to close and open Adobe Photoshop CS2. But I need it to work on a few adoptables! I need it NOW!
Nov 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Wacom Intuous
Make sure the Wacom system preferences has the default settings for the buttons. Also check the intuous website for the latest driver for 10.5.
Nov 19, 2007 | Wacom Intuous3 A6 (ptz430gen) Graphic...
Wacom (EP130EPE) Digital Pen Logo
8,445 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
