Phillips rear projection tv has a clear picture but has a pink tint to the screen. How do I fix it
    Novelist:
    Champion:
  • 203 Answers
The most common problem for this is a fungus in the coolant of the tubes. In order to fix this you will need to replace the fluid in the tubes. If you are wanting to tackle this yourself you will first need to take the back off and look down in the tubes, the red tube should look clear and the other two you will probably find look like there is some fungus inside them. If this is the case and you want to tackle it yourself, let me know and I will email you a PDF file on how to complete the job. A repair man should cost your somewhere around $300-$400 to fix it. If you look down in the tubes and they all look clear we may have a different problem, if thats the case let me know and we will troubleshoot further.
Posted on Sep 18, 2008
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a philips dptv310 55'' rear projection tv... everything works but picture is in constant red tint... any fixes
The Phillips are famous for the coolant needing replacement in the blue and green CRTs which make the screen take on a red tint and the pic will appear dull. You can get the Phillips coolant Kit at www.tvrepairworld.com The kit also contains the CD with instructions
Nov 26, 2009 | Televison & Video
Picture is not clear. Has a green tint and glow.
Repalce the coolant in the CRTs. You can get the Phillips CRT coolant replacement kit at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Oct 13, 2009 | Philips 50P8341 50" Rear Projection...
55'' rear projection Phillips (dptv335) Red Tint in 4:3 area
Sounds like your fluid in the CRT's need replaced. I would recommend a servicer take care of that problem. The corrosion that ethylene glycol can do to components is vast if you spill it on any of the PC boards. ( You know it as Anti-freeze ). Play it safe---Make a Call.!
Jul 24, 2009 | Pioneer Televison & Video
The color is bad
my rear projection Phillips TV Picture has a green tint.
Jan 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
