Question about Xerox WorkCentre Pro 412 All-In-One Laser Printer
Printer wont pick up paper
Printer won't pick up paper from the tray . It tries but it won't pick it up and then it says there is a paper jam(0) but there's not and the paper supply won't let me bypass the casette to go to a different paper supply. All the rollers have been replaced. I need to cancel the saved job from a fax trying to come in. HELP ME PLEASE!
    Problem Solver:
  • 7 Answers
In my experience with these little monsters, I found that sometimes toner drops from the developer unit to the paper transfer area and blocks the paper sensor, you will have to unplug it and remove all (drum unit, Developer unit and drawer) and check the sensors along the way up from the drawer along the paper path leading to the actual drum area, and only with a vacuum Preferably a shop Vac that has enough suction, Home Vacs aren't strong enough. Good Luck
Posted on Sep 18, 2008
Canon Mp550 paper jam
If the paper is not being picked up from the tray assembly try applying mild soap to a soft cloth and clean the paper pick up rollers. Do not use rubbing alcohol because it will dry the rubber out so later they won't pick up at all
Sep 18, 2012 | Canon Office Equipment & Supplies
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
Where is this sensor(paper jam 0)?
For this you need to open back pannel of printer starting from page pick roller check the path of paper,check aroud when you'll open back pennel.
Mar 03, 2011 | Xerox WorkCentre 3119 Laser Printer
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Imageclass mf5530 jams from paper tray, bypass
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Jul 04, 2010 | Canon imageCLASS MF5530 All-In-One Laser...
Paper jam and now printer wont work since all paper has been cleared out of printer
paper pick-up rollers may be warn out.replace rollers.tell me the company &model no.
Aug 04, 2008 | Office Equipment & Supplies
Xerox WorkCentre Pro 412 All-In-One Laser Printer Logo
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
